Cant remove cable from test board and wire issue and green light problems Options
westonboy88
#1 Posted : 23 February 2018 18:14:27
Rank: Newbie
I'm trying to remove the red orange and yellow wire that connects the right leg to the test board but I can't remove it also in issue 53 when the leg is off the table the green light does not go off
#2 Posted : 23 February 2018 19:01:18
Hi WB
If you look at the outside face of the socket on the test board there is two slots these hold the two teeth on the connector in place generally wiggling the connector in a sideways motion will free the two teeth and allow the connector to free itself.
Your light problem may be down to a faulty test board so contact C/S for a replacement board.
This page was generated in 0.781 seconds.
