here are the parts for this issue. stevegbr attached the following image(s):
first remove the support strut, no longer required, then we do the locking mechanism for the bonnet. stevegbr attached the following image(s):
no we connect the front of the car to the rear. held by eight screws. stevegbr attached the following image(s):
here is issue 62. stevegbr attached the following image(s):
first we attach the windscreen which is secured by eight screws. stevegbr attached the following image(s):
now for the rear view mirror, which i am not sure yet if i should keep it. stevegbr attached the following image(s):
and pressed on to the windscreen. stevegbr attached the following image(s):
and here is issue 63. stevegbr attached the following image(s):
first we do the hinges for the bonnet. stevegbr attached the following image(s):
then the anchors for the bonnet supports. stevegbr attached the following image(s):
and then the support rods. stevegbr attached the following image(s):
thats it for this month, next issue we get the luggage compartment.
Great to see the body  starting to look like a Delorean now Steve  great update  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Great update Steve, looks like a Delorean now. Mark Regards Markwarren (Mark) Admin
thanks mark, you need strong hands to hold it together as well.
Good to see the larger parts arriving  will look forward to seeing them get added Al
Steve is it my eyes or the angle of the camera but does one of the bonnet supports look longer than the other  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Guest (28)
