Tips on removing shine on tires? Options
Fhan
#1 Posted : 25 February 2018 18:08:08
Rank: Beginner Level 1
Hello,
I just after many years of covering this model was able to afford the subscription. Now as the parts are arriving I’ve spent a lot of time looking at all the diaries for tips which there are many great ones! The only I didn’t see in detail was what the best way was to remove the shine and the mold seam from the tire. I assume sanding was a good option but wasn’t sure about the proper technique or grit sandpaper. Any advice would be greatly appreciated.
#2 Posted : 25 February 2018 22:02:51
BigGrin Hi
I bought a mixed set of wet and dry paper from a car accessories/paint store grit 250 to 1200 and using the roughest grit 1st worked my way through to the smoother grit to get a good finish.
You can see my tyres by scrolling down to post #60 here:-
http://forum.model-space...sts&t=15033&p=3
#3 Posted : 25 February 2018 22:06:33
I use the roughest I can find, even down to 80 grit.
Then up to about 600 to finish.
Be prepared for a LOT of mess and very black hands.
#4 Posted : 25 February 2018 22:37:11
BigGrin We are talking racing slicks here so a gentler approach is needed and take care around the edges so not to scuff the tyre wallsCool
#5 Posted : 26 February 2018 09:46:05
On my Pocher Ducati I used serious rough grade, then finer.
The tyres were as hard as nails with a horrible seam around the middle of the tread.
They needed very tough work.
#6 Posted : 26 February 2018 11:13:59
Can’t be that rough with the F1 tyres as they are more delicate and have side wall logos to avoid.
Fhan
#7 Posted : 27 February 2018 08:00:12
Thanks everybody. This is a great start
This page was generated in 0.330 seconds.
