Joined: 19/06/2014 Posts: 79 Points: 219 Location: Doncaster
Have come to fit front lower panel and it has warped out of shape, because I had to wait 3 months before I could fit it. Not happy
Hi Ncal The front plate is quite thick plastic and should be stored in its blister pack until needed to prevent any damage to it. If the item is no longer of use simply order a new part from C/S. Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
left it in pack, but still warped. have contacted cs but no reply yet
We’ve not had any such reports of warpage. It’s always fastes to call rather than email.
Joined: 24/09/2012 Posts: 79 Points: 225 Location: Gloucestershire
Same here, front panel badly warped. at least 4mm away from holes lining up. Will contact parts people. This is obviously an issue. Mine was kept in the blister pack in a cool dry place in a plastic box so it was kept safe. HMS Victory, Spitfire, MP 4-23, D51, T72, Honda CB750, Harley Davidson, Hayabusa, Ducatti 1299, E-Type, Mustang and Porsche 911, VW T1 Samba. Many others from other suppliers on the go!
HMS Vic wrote:Same here, front panel badly warped. at least 4mm away from holes lining up. Will contact parts people. This is obviously an issue. Mine was kept in the blister pack in a cool dry place in a plastic box so it was kept safe. We’ve had just 3 reports out of 1000’s sold across the world.
