Dry fit to BlockRM1 attached the following image(s):
Now it's looking like a race car RM1 attached the following image(s):
 Very nice Malc certainly looking the part now Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Some progress made on the front end .RM1 attached the following image(s):
A dry fit to see how it looks.RM1 attached the following image(s):
 Looking very nice Malc with the nose on, top work as always Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,145 Points: 21,742 Location: Northamptonshire, England
Coming along very nicely. Mark Regards Markwarren (Mark) Admin
Sincere apologies Malc, I normally comment on your excellent F1 car builds but somehow I've managed to miss the last couple of updates. However, I have just caught up with your build and have to congratulate you on what is fast becoming a beautiful build of a beautiful car, very well done indeed mate!
I think the M19C is one of the most aesthetically pleasing F1 cars ever to have been designed, such beautiful lines and I can understand why you've chosen this kit, I would have chosen it too, it just looks stunning in the Yardley colours.
Kev
Thanks guys. This is a very nice model to build ! You're right, Kev, it will look great in the Yardley Livery. Malc.
I had a bit of a problem with the wind shield . It's a vacuum formed piece that has to be cut from the moulding. I'm sure many of you fellow modelers are used to this but for me it was a first ! The material is very thin and in handling I managed to get a couple of "marks" on it. No problem...... polish out with micromesh. Didn't work and it went sort of dull .
MFH were very good with supplying a replacement although it took a couple of weeks to reach me. Second one done and looking ok. RM1 attached the following image(s):
The airbox is in two pieces. Some filling and smoothing needed.RM1 attached the following image(s):
I'll fit the screen later when all the engine parts have been joined to the body.RM1 attached the following image(s):
Nice work Malc, looking excellent. Mark Regards Markwarren (Mark) Admin
 Nice work on the airbox Malc and looking good Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Lovely work Malc  the detail on the kit is outstanding  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
You did a superb job on filling and smoothing the airbox joint Malc and the whole car is looking really good.
A coat or two of 'Johnsons' Klear would probably have corrected that dull windscreen Malc, but no matter, the replacement turned out brilliantly, well done.
Kev
Thanks for all the comments guys .
ModelMania wrote:You did a superb job on filling and smoothing the airbox joint Malc and the whole car is looking really good.
Kev  Hi Kev. Thanks for the tip on the "Johnsons klear". I'll see if something similar is available here. I can experiment on the old screen. Good info for the future. Malc.
Guest (6)
