26 Pages 123>»
MWG build diary of the Bark HMS Endeavour Options
#1 Posted : 07 June 2011 09:26:46
This is the place where I will record my build.I am up to part 19.
#2 Posted : 07 June 2011 09:32:29
[/img]
ENDEAVOUR 001.jpg (2,404kb) downloaded 73 time(s).
ENDEAVOUR 002.jpg (2,841kb) downloaded 60 time(s).
#3 Posted : 07 June 2011 09:49:02
The first 2 pics are of the finished keel
The next 5 pics show how I strengthen the ribs, using balsa wood, it also gives a firm base for planking the hull.
My preffered adhesive is Aliphatic
The next pics show all the fillers in place.
ENDEAVOUR 007.jpg (2,754kb) downloaded 60 time(s).
ENDEAVOUR 008.jpg (2,589kb) downloaded 51 time(s).
ENDEAVOUR 010.jpg (2,999kb) downloaded 52 time(s).
ENDEAVOUR 011.jpg (2,626kb) downloaded 52 time(s).
ENDEAVOUR 012.jpg (2,568kb) downloaded 51 time(s).
#4 Posted : 07 June 2011 10:12:04
All the balsa fillers in place.
ENDEAVOUR 013.jpg (2,954kb) downloaded 55 time(s).
ENDEAVOUR 014.jpg (2,539kb) downloaded 47 time(s).
ENDEAVOUR 015.jpg (2,559kb) downloaded 53 time(s).
ENDEAVOUR 016.jpg (2,531kb) downloaded 52 time(s).
ENDEAVOUR 019.jpg (2,517kb) downloaded 51 time(s).
ENDEAVOUR 020.jpg (2,342kb) downloaded 51 time(s).
ENDEAVOUR 021.jpg (2,396kb) downloaded 58 time(s).
#5 Posted : 07 June 2011 10:50:48
Ok, on to the next part of my build.
I decided to deviate from the build instructions at this point, at no time did I plank the decks in parts (as per the instuctions) I joined all the deck parts together and planked them as a complete deck.
Starting with the lower deck,the Forecastle, The waist and finally the stern deck.
The wood supplied for planking is Ayous.
I did not use contact adhesive, prefering Aliphatic to plank the decks.
ENDEAVOUR 005.jpg (3,514kb) downloaded 59 time(s).
ENDEAVOUR 004.jpg (3,537kb) downloaded 56 time(s).
ENDEAVOUR 003.jpg (3,034kb) downloaded 53 time(s).
#6 Posted : 07 June 2011 11:08:32
We are up to part 15 at this point.
Its time to make the frame of the scuttle cover (lid) of the forecastle deck. I followed the instructions, the only change I made was to the stain.
At part 16 I had already fitted the decks
ENDEAVOUR 022.jpg (1,870kb) downloaded 60 time(s).
ENDEAVOUR 023.jpg (1,897kb) downloaded 56 time(s).
#7 Posted : 07 June 2011 11:22:52
At part 17 we fit the ladder to the scuttle,a part is supplied to rest the ladder on (20mmx20mm wooden block) I decided to not use this as I had a vision of the crew going down the ladder and falling off the block.
I built an extra piece of deck, planked and fitted it. you can now see deck at the bottem of the ladder.It does not change the build, but I feel better.
ENDEAVOUR 034.jpg (1,662kb) downloaded 59 time(s).
ENDEAVOUR 033.jpg (3,071kb) downloaded 55 time(s).
ENDEAVOUR 032.jpg (1,416kb) downloaded 52 time(s).
ENDEAVOUR 039.jpg (2,399kb) downloaded 49 time(s).
ENDEAVOUR 038.jpg (1,862kb) downloaded 49 time(s).
#8 Posted : 07 June 2011 11:42:43
This is now part 18, fitting the two bow exterior bulwarks. I cut out the piecesand soaked them in hot water for 30 mins.
Then fitted them to the bow (wet) and left over night to dry, the next day I glued and fitted them properly.
ENDEAVOUR 024.jpg (2,588kb) downloaded 52 time(s).
ENDEAVOUR 027.jpg (2,615kb) downloaded 52 time(s).
ENDEAVOUR 025.jpg (3,112kb) downloaded 48 time(s).
ENDEAVOUR 026.jpg (2,807kb) downloaded 49 time(s).
#9 Posted : 07 June 2011 12:00:17
Now up to date with part 19. this involves fitting the bow interior frameworks.I prepared the pieces as per the instructions, the only change I made was to fit both sides in one go,instead of left side (port) now and the right side (starboard)when ever the next part arrives.
When building I like to keep both sides equal prevents twisting etc.
ENDEAVOUR 028.jpg (3,447kb) downloaded 56 time(s).
ENDEAVOUR 029.jpg (3,049kb) downloaded 50 time(s).
ENDEAVOUR 030.jpg (2,789kb) downloaded 52 time(s).
ENDEAVOUR 031.jpg (3,011kb) downloaded 50 time(s).
ENDEAVOUR 035.jpg (2,946kb) downloaded 51 time(s).
ENDEAVOUR 037.jpg (2,488kb) downloaded 52 time(s).
#10 Posted : 07 June 2011 12:31:19
While I am waiting for parts 20/21/22/23,I thought I would fit the 4 stern frames this i how they look
ENDEAVOUR 017.jpg (2,995kb) downloaded 54 time(s).
ENDEAVOUR 016.jpg (2,531kb) downloaded 51 time(s).
ENDEAVOUR 018.jpg (2,397kb) downloaded 51 time(s).
ENDEAVOUR 021.jpg (2,396kb) downloaded 51 time(s).
#11 Posted : 07 June 2011 12:40:30
Finally for this session, untill I receive more parts, thank you for looking at my build,and this is how "she" looks at the moment.
ENDEAVOUR 006.jpg (3,084kb) downloaded 55 time(s).
ENDEAVOUR 043.jpg (3,252kb) downloaded 54 time(s).
ENDEAVOUR 041.jpg (2,392kb) downloaded 52 time(s).
ENDEAVOUR 042.jpg (2,064kb) downloaded 62 time(s).
ENDEAVOUR 040.jpg (2,967kb) downloaded 70 time(s).
#12 Posted : 07 June 2011 14:03:01
can you please download from photo bucket,it take me ages to download from this sita,tayou jumped the gun me thinks,you compleated the bow bulwarks tut, tut,i was going to do the same,but learn't me lesson.wait for nod,something else might have to be done,BigGrin
#13 Posted : 10 June 2011 21:44:54
I believe I have solved my problem of putting photos on the Forum,lets hope I can remember how I did it!!!!!BigGrin Blink Confused Laugh
#14 Posted : 10 June 2011 21:50:53
My, someone's been busy BigGrin
#15 Posted : 10 June 2011 22:01:07
I have Mr T, determined to master it!!!!
#16 Posted : 11 June 2011 00:36:00
what an excellent job you did,nice build,and very professional.
#17 Posted : 11 June 2011 00:45:12
Thank you again Karl, thats praise indeed,I appreciate it (cant spell but you know what I mean!)Blushing
#18 Posted : 11 June 2011 10:44:40
hi mwg,your speeling is beter then mine,I've looked all over e-bay canknot find a kaybord that can speel,wiling too pae big bucks for one.
#19 Posted : 11 June 2011 16:53:39
If you find one, buy one for me!!Mellow
alantait
#20 Posted : 12 June 2011 00:17:19
you sad gits Laugh Laugh Laugh have you nothin better to doLOL
current builds
26 Pages 123>»
This page was generated in 0.354 seconds.
