[size=8]Nice idea with the jig!size] Greetings, Walter
Very nicely done with that jig, a great idea. Regards Paul Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Ahoy shipmates, Thanks for the positive comments, much appreciated. Further work done on Issue 74: - Entry port parts decorated with gold paint - They fitted onto both sides of the hull - Started to fit the side ladder, steps completed on one side. I also added a little radius on the outer corners, to make them look more gentle, also a little inset picture shows in the magazine that they are also rounded on the real ship. gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
Nicely done Laszlo, the steps and entry port look great. Regards Paul Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Issue 74 almost completed: - Step supports added. I customised them a bit with rounded edge and ends. - Fender base strips fitted gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,273 Points: 22,126 Location: Northamptonshire, England
Lovely work, looks great. Mark Regards Markwarren (Mark) Admin
All looking good, very neat and tidy.... Regards Alan
Very nice work, looks great.
Looking good!Greetings, Walter
Today I finished Issue 74. - fenders fitted on both side. The next job which I'm scared of... painting the yellow/black stripes on the sides...  Will start tomorrow.... well... only if I won't be too much scared... gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
With your attention to detail i'm sure you're going to do a fantastic job on your painting Laszlo, relax take your time and make sure the edges on your masking are stuck down really well, i'm looking forward to seeing your results. Regards Paul Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Looks excellent, I’m sure you will make a very fine job of it. Mark Regards Markwarren (Mark) Admin
Issue 75 Started to paint the hull. First coat of yellow ochre paint applied on both side. It wasn't that scary as I expected. Second coat will come tomorrow. gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
Nice start Laszlo, scariness gone is a good thing. Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Looking good, very nice work.... Regards Alan
Thanks All. Today I applied the second coat. Very pleased with the result, there is no different shades (compared my copper painting), managed to make a uniform colour all around. I will start masking tomorrow for the black stripes. This time with more confidence since the success with the yellow paint. gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
Issue 75 continued.  With some fear I started to work on the black stripes. I started with the "hidden" side, which will be towards the wall when the finished ship will be displayed. I applied the masking tape. I had difficulties to get the tape straight where the line crosses the wriggles and the steps. Even if I tried it with 1.5 mm wide Tamiya masking tape, I couldn't get it nicely straigth. At the end I used the 6mm tape and just let it run over the wriggles, without tucking it around them properly. After all tape added I applied the first coat of black paint, leaving some unpainted zones around the delicate areas. I will try to make a straight line freehand after I removed the tapes.  Tomorrow I'll add a second coat, surprisingly the yellow paint does show through the black paint a bit, but it can be because I added few drops of water to the paint to make it a slightly thinner. I wanted to avoid a "step" between the black and yellow paint after the masking tape removed, which might occur if the paint is too thick. gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
A good idea to do the hidden side first, looking forward to seeing how it turns out. Regards Paul Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Issue 75, hidden side. Second coat of black paint applied. After it dried masking tape removed... 🥁🥁🥁 ta-daaa... awesome Very little bleeding under the tape... Leftover delicate areas painted freehand... not for someone with shaky hands Still at few places require correction with yellow but in overall very happy with the result...  Tomorrow will touch up with yellow and start masking the "display side". With less fear, seeing that I'm on the right track. gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
Guest (49)
