36 Pages 123>»
MWG build diary of Nelson's HMS Victory Options
#1 Posted : 07 June 2011 19:14:41
Here will be my build of HMS Victory.
I will be painting it,and adding copper tiles,and following Mr T`s build. I have part built the launch and hear it is;-
#2 Posted : 07 June 2011 21:36:40
Here are some pics of "she" herself. Please note the use of Balsa fillets at the stern and bow, I also used them along the keel of the hull
#3 Posted : 07 June 2011 21:55:14
My Victory has now had her hull planked which I will show you next time, thank you for looking.
#4 Posted : 07 June 2011 22:47:51
Hi MWG,
Just had a look at your pictures,there looking very good to me,you have filled in the bow which has made your planking very smooth,but like me still a long way to go.Thanks for sharing your pictures.
Regards tf64.
#5 Posted : 07 June 2011 22:53:20
Thank you tf64.
The pics go back aways, I have finished planking and I will post them in a couple of days
#6 Posted : 08 June 2011 09:10:24
Thes are the photos of the planked Hull from variou angles.
#7 Posted : 08 June 2011 09:14:17
Good to see your efforts, if you reduce the file size of each photo then photos will then appear without having to download
#8 Posted : 08 June 2011 09:31:16
The last couple of pics, show the deck between the entrances,I did the simulation as instructed but I did not like it, so I used planks left over from The Endeavour and planked the area, I know you can not see it but I know it is there!
#9 Posted : 08 June 2011 09:39:11
The next jobs will be to stain that middle deck, and fit the sides to the entrances in dark wood.
Then fit the keel. thats all for now!!BigGrin
#10 Posted : 08 June 2011 09:43:39
Good morning Mr T,
Do you reduce the size on my PC or on the postConfused sorry to be a pain.
As you can see I prefer to use the pics off my PC.
Thank you!
#11 Posted : 08 June 2011 09:58:52
Needs to be reduced in your PC
#12 Posted : 08 June 2011 22:50:16
Nice job with your planking MWG bet your glad to see the end of that,now you can constraint on the rest.I think i have a problem with the bow regarding the planking, as i have a gap which looks a bit tricky to get rid of,not to shore which to go yet,but looking at your pictures i hope mine turn's out as good.
Regards tf64.
#13 Posted : 08 June 2011 23:13:37
Thank you tf64, you bet I am glad the planking is finished.
You won`t be far behind, I am sure your build will be great. do you want to show a photo of the gap?
Kind regards
#14 Posted : 08 June 2011 23:28:15
MWG i will post you a picture 9/6 thanks for your intrest.
tf64.
#15 Posted : 08 June 2011 23:35:42
No problem tf64speak tomorrowMellow
#16 Posted : 09 June 2011 18:37:23
One of our favourite places I Menorca, its the place my wife and I got married, I happenned to visit the Martime museum at Es Castell, just thought you might like to see this (will show others periodically)
MWG ALBUM 1 064.jpg (2,270kb) downloaded 118 time(s).
MWG ALBUM 1 062.jpg (2,551kb) downloaded 110 time(s).
#17 Posted : 10 June 2011 22:46:48
For those of you who like to see photos instantly here goes!!
#18 Posted : 10 June 2011 23:00:58
I have now finished the lower centre Deck which should have been simulated (and I prefered to plank it)you will see before and after.also attached is the stain and varnish I used.
I also prepared the panels from offcuts from San Francisco 11 planking, which I mounted on black plastic card.
You will see before and after sanding.
#19 Posted : 11 June 2011 01:37:05
Next job is to fit the side panels to the ships entrances ( this is not in the instructions only me doing some enhancments)(Mods) and then fit the ships keel(bottem Stern and Bow)For those of you who like instant photos, they have now been added tothis thread.
#20 Posted : 11 June 2011 10:42:37
With the exception of the figures and gratings, the item looks a dead ringer for the Mantua Carronade dio kit
36 Pages 123>»
This page was generated in 2.674 seconds.
