fighting top a bit of help please tomick Options
saintsman123
#1 Posted : 09 June 2011 17:40:04
How important are the positioning and spacing of the 0.7mm holes as at step 2 page 12 (issue 61)?
The reason I ask is that one of the holes is drilled 24mm from the outside, and (due to tolerances I assume) the edge of the inside space is 25mm from the outside,if I drill the hole at 24mm I am worried it may be too close to the edge.
Come on you Jimmies
#2 Posted : 09 June 2011 18:50:18
Have checked with the design team, the hole is in fact close to the edge and it is important the spacing is as per that shown, though the photo which relates to the 24mm hole has a minor discepency in showing the hole further in from the edge than where it actually falls, and should be closer to the edge.
So to recap, the measurements are correct and maintain the spacing shown.
saintsman123
#3 Posted : 10 June 2011 16:34:21
Thanks for thatBigGrin
Come on you Jimmies
This page was generated in 0.027 seconds.
