35 Pages «<1415161718>»
Laszlo For's Diary Options
Gibbo
#301 Posted : 23 March 2018 23:55:19
That looks fabulous, well done Laszlo.
Paul
z8000783
#302 Posted : 24 March 2018 09:33:09
Groups: Unapproved
Very nice Laszio.
You may want to carefully take of the black where it is has bled, with fine glass-paper before paining, since yellow over black doesn't cover too well. You can then touch up the black or yellow where necessary.
gingerale75
#303 Posted : 24 March 2018 11:01:09
z8000783 wrote:
Very nice Laszio.
Thanks John for the advise.
First I need to check what is a glass-paper... LOL never heard of it Blink
Happy building!
Laszlo
Finished builds: HMS Victory, HMS Victory Cross-Section
z8000783
#304 Posted : 24 March 2018 11:03:16
Groups: Unapproved
Most people know it a sandpaper. Sorry.
gingerale75
#305 Posted : 24 March 2018 11:06:49
Ah... OK... BigGrin I guess a very-very fine one.
Happy building!
Laszlo
willz
#306 Posted : 24 March 2018 15:15:09
Active Service Medal: 500 post active service MedalTurquoise Medal: Turquoise Medal for model making know-how contributionOutstanding Build: An award for an outstanding buildBuild-Diary Medal: Build-Diary Medal of Honour
useful tip for masking,,,,,all the yellow is done,, so when you mask it up for the black strips you first go down the edge of the masking with the yellow and let it dry,,,,this seals the edge to be painted back and any bleed into the yellow will be yellow......
cheers Willz
gingerale75
#307 Posted : 25 March 2018 01:10:51
Thanks for all the comments and advice, all took into account on the "display side".
First I corrected the bleedings on the port side, now it's complete and looks fantastic.
Then started the starboard side, masking tape and first coat of black applied, hopefully with all the hints used there will be no bleeding on this side. BigGrin
Second coat comes tomorrow.
gingerale75 attached the following image(s):
Happy building!
Laszlo
#308 Posted : 25 March 2018 09:26:51
That does look rather excellent. Great work. BigGrin ThumpUp
#309 Posted : 25 March 2018 12:45:40
Coming along well Cool
#310 Posted : 26 March 2018 08:39:07
Nice update. Doing a great job.
Chris Cool
#311 Posted : 26 March 2018 08:41:30
Nicely done BigGrin progressing well.
gingerale75
#312 Posted : 26 March 2018 23:14:01
Thanks for all the positive comments, well appreciated.
Issue 75 continued
- Second coat of black applied yesterday.
- Today I removed the masking tape and corrected the tiny bleeding around corners and the wriggles.
- Beakhead also painted black.
I declare the result as a very successful task on both side of the ship.
Sorry if this sentence doesn't make any sense. Laugh
Very please with the result of the most scary task so far for me. Cool Flapper BigGrin ThumpUp
Happy building!
Laszlo
#313 Posted : 26 March 2018 23:25:07
And you were worried about the task of painting the bands... looks to me like you had nothing to worry about.... looks great, very well done....Cool Cool
gingerale75
#314 Posted : 26 March 2018 23:30:36
Thanks Alan,
It was still the most scary thing so far on the build, even if the end result looks like that it was an easy-peasy job. BigGrin
Happy building!
Laszlo
Gibbo
#315 Posted : 26 March 2018 23:42:47
A great piece of painting Laszlo, i'm really pleased for you that it turned out so well.
Paul
gingerale75
#316 Posted : 29 March 2018 23:32:43
Thanks for the good comments.
Issue 75 continued
- all the gun ports lining painted red ochre, including the ones on the quarterdeck
- entry port linings painted brown.
Now painting is finished for a while... phew... LOL Cool
Happy building!
Laszlo
#317 Posted : 29 March 2018 23:39:32
Looks like your enjoying the build, well done so far Cool
gingerale75
#318 Posted : 31 March 2018 21:42:31
Issue 75 continued.
Started to work on the chainwales.
- Inside edges shaped to fit to hull
- holes drilled for eyebolts and supports
- they painted black
- eyebolts and blocks fitted
- started to wrap the deadeyes with brass wire. It took a while to figure out the correct technique because the wire was keep snapping even after a half twist around the deadeye. After finding the right method was able to made quite a lot of them. But now I had to stop because my fingers are numb. Crying LOL
I had a look few pictures from other build diary, also from the real ship and I noted that the deadeyes are actually black. I double checked the magazine (and the official build) and it will paint black only the wires underneath the chainwales but will leave the deadeye natural.
I'm thinking that I'll paint them black too to have a more authentic look. I'll prepare all with the brass wires, also making the straps and all together with the supports and the "8-shaped" links I'll hang them onto a piece of thread and spray them first with primer and then with matt black.
Happy building!
Laszlo
gingerale75
#319 Posted : 01 April 2018 12:19:45
First of all, Happy Easter to all of you!
As I mentioned I'm going to paint black not just the wires but the deadeyes too.
To make me able to do it easily, first I made a frame from some leftover timber.
Then I hung them all onto a strung thread and sprayed with primer.
Happy building!
Laszlo
gingerale75
#320 Posted : 01 April 2018 22:21:51
Very productive day today. Cool
- After primer dried deadeyes sprayed with black paint
- while waited to get it dry the gallery support blocks were shaped and fitted
- rear of gallery support sanded to shale
- deadeyes fitted to the chainwales, closing strips will be fitted tomorrow.
Happy building!
Laszlo
Guest (36)
This page was generated in 0.430 seconds.
