That looks fabulous, well done Laszlo. Regards Paul Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Very nice Laszio.
You may want to carefully take of the black where it is has bled, with fine glass-paper before paining, since yellow over black doesn't cover too well. You can then touch up the black or yellow where necessary.
z8000783 wrote:Very nice Laszio.
You may want to carefully take of the black where it is has bled, with fine glass-paper before paining, since yellow over black doesn't cover too well. You can then touch up the black or yellow where necessary. Thanks John for the advise. First I need to check what is a glass-paper...  never heard of it Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
Most people know it a sandpaper. Sorry.
z8000783 wrote:Most people know it a sandpaper. Sorry. Ah... OK...  I guess a very-very fine one. Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
useful tip for masking,,,,,all the yellow is done,, so when you mask it up for the black strips you first go down the edge of the masking with the yellow and let it dry,,,,this seals the edge to be painted back and any bleed into the yellow will be yellow...... cheers Willz
Thanks for all the comments and advice, all took into account on the "display side". First I corrected the bleedings on the port side, now it's complete and looks fantastic. Then started the starboard side, masking tape and first coat of black applied, hopefully with all the hints used there will be no bleeding on this side. Second coat comes tomorrow. gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,273 Points: 22,126 Location: Northamptonshire, England
That does look rather excellent. Great work. Mark Regards Markwarren (Mark) Admin
Coming along well
Nice update. Doing a great job. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Nicely done  progressing well. Al
Thanks for all the positive comments, well appreciated. Issue 75 continued - Second coat of black applied yesterday. - Today I removed the masking tape and corrected the tiny bleeding around corners and the wriggles. - Beakhead also painted black. I declare the result as a very successful task on both side of the ship. Sorry if this sentence doesn't make any sense. Very please with the result of the most scary task so far for me. gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
And you were worried about the task of painting the bands... looks to me like you had nothing to worry about.... looks great, very well done.... Regards Alan
Gandale wrote:And you were worried about the task of painting the bands... looks to me like you had nothing to worry about.... looks great, very well done.... Regards Alan Thanks Alan, It was still the most scary thing so far on the build, even if the end result looks like that it was an easy-peasy job. Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
A great piece of painting Laszlo, i'm really pleased for you that it turned out so well. Regards Paul Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Thanks for the good comments. Issue 75 continued - all the gun ports lining painted red ochre, including the ones on the quarterdeck - entry port linings painted brown. Now painting is finished for a while... phew... gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
Looks like your enjoying the build, well done so far
Issue 75 continued. Started to work on the chainwales. - Inside edges shaped to fit to hull - holes drilled for eyebolts and supports - they painted black - eyebolts and blocks fitted - started to wrap the deadeyes with brass wire. It took a while to figure out the correct technique because the wire was keep snapping even after a half twist around the deadeye. After finding the right method was able to made quite a lot of them. But now I had to stop because my fingers are numb.  I had a look few pictures from other build diary, also from the real ship and I noted that the deadeyes are actually black. I double checked the magazine (and the official build) and it will paint black only the wires underneath the chainwales but will leave the deadeye natural. I'm thinking that I'll paint them black too to have a more authentic look. I'll prepare all with the brass wires, also making the straps and all together with the supports and the "8-shaped" links I'll hang them onto a piece of thread and spray them first with primer and then with matt black. gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
First of all, Happy Easter to all of you! As I mentioned I'm going to paint black not just the wires but the deadeyes too. To make me able to do it easily, first I made a frame from some leftover timber. Then I hung them all onto a strung thread and sprayed with primer. gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
Very productive day today.  - After primer dried deadeyes sprayed with black paint - while waited to get it dry the gallery support blocks were shaped and fitted - rear of gallery support sanded to shale - deadeyes fitted to the chainwales, closing strips will be fitted tomorrow. gingerale75 attached the following image(s): Happy building! Laszlo Finished builds: HMS Victory, HMS Victory Cross-Section
Guest (51)
