I'm not a ship builder but I was you tubevthe othervday and came across this peice of awesomeness. Check it out. http://www.youtube.com/w...re=youtube_gdata_player
What a fantastic craftsman. thanks for finding it Austin, brilliant!!!! MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
That is really something!! Thanks for posting it...  Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Joined: 25/03/2011 Posts: 1,027 Points: 3,075 Location: Lincolnshire
This modeller is probably using a CNC machine program and a plasma cutter to produce these parts. It's all in the preparation, if the dimensions are accurate, a CNC can construct components that will fit together like a Swiss watch. Beautiful!
Scratch my last, he had it done at nearby factory with a laser cutter and his program was AutoCad.  That's what you get for not reading the text first Lol.
Yes the laser cutter has done all the hard work, but it's no instruction, it's not like a normal model it must take a lot of skill just to put it together. The guy is talented.
Austin wrote:Yes the laser cutter has done all the hard work, but it's no instruction, it's not like a normal model it must take a lot of skill just to put it together. The guy is talented. Totally with you on that Austin, the guy is talented no doubt about it. Beautiful model! What I meant in my previous posts was I thought he had cut the parts with a CNC, and then I found out it was a laser because I had not read the thread properly. Total respect to this guy!
