2 Pages <12
Sponsor decals Options
#21 Posted : 02 April 2018 09:28:55
BigGrin Hi ManDan
The car already has a good shiny finish as supplied so all I did was to add the extra decals but made sure they were well stuck down by using a decal softener and mine still look good after a couple of years. If you clear coat it will mean doing all the body work so it all matches the choice is yours.
ManDan
#22 Posted : 03 April 2018 01:33:30
Rank: Beginner Level 3
BigGrin Hi ManDan
Thanks Andy!
This is what I was looking for. I plan to use Solvaset to place the decals. I just wasn't sure if it needed any top coating. Thanks much!
#23 Posted : 03 April 2018 07:33:16
BigGrin No problem will you be posting some pics of your buildCool
ManDan
#24 Posted : 25 May 2018 08:30:16
Yes! I plan to start building this weekend... very nervous. I don't to mess it up!
#25 Posted : 25 May 2018 09:28:24
BigGrin Take your time and use tooth picks to apply small amounts of glue and you will be fineCool
ManDan
#26 Posted : 26 May 2018 23:08:58
Thanks, I will. Another question, if you don't mind, for the rear wing Marlboro decals, should i apply those before assembly? Is there a downside to doing this?
#27 Posted : 27 May 2018 07:38:11
BigGrin I added the decals just before final assembly and it was less hastle to line the two decals up on the front face of the rear wing that way but its your choice and do what you feel happy with.Cool
2 Pages <12
This page was generated in 2.399 seconds.
