106 Pages «<979899100101>»
Sticky Wickett
#1961 Posted : 05 April 2018 12:05:53
Spal wrote:
Lovely job on that decking Phil Cool now for the other half LOL
Thanks Al!Cool Yes mate, now the other half.LOL I will be fitting the accommodation space hatch, hinges and various cleats and locating eyes during this stage too.
Phil W.
CaptnBirdseye
#1962 Posted : 05 April 2018 12:12:25
Rank: Superelite
Hi Phil,
Can't be not impressed with your build Drool
It has masses of detail, and that planking looks supurb!
Well done Cool
Gray
Sticky Wickett
#1963 Posted : 05 April 2018 12:31:57
CaptnBirdseye wrote:
Hi Phil,
Well done Cool
Gray
Thank you very much Gray!Cool I'm glad you like all the detailing. The decking has given the boat a whole new look in keeping with it's era.
Phil W.
#1964 Posted : 05 April 2018 18:47:08
The contrast of the colours really makes the deck stand outDrool you are doing a superb job PhilCool regards PhilCool
Sticky Wickett
#1965 Posted : 05 April 2018 19:39:31
Thank you very much Phil!Cool The decking will receive a wash of dark grey almost black to simulate the anti-fouling paint used on the real boats to protect the wood. The contrast will change, but the look of the wood won't.
My intention is to then gently sand back the dark wash to reveal the wood grain beneath.
Phil W.
DaDokta
#1966 Posted : 11 April 2018 07:06:02
The deck is looking awesome, Phil!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
Sticky Wickett
#1967 Posted : 11 April 2018 12:03:47
Thank you very much Walter!Cool
Phil W.
Sticky Wickett
#1968 Posted : 12 April 2018 22:08:16
This weeks update of my 1/48 scale U230 U-boat build sees further detail added to the casing.
The attached photo shows the accommodation space hatch fitted in place.
Sticky Wickett
#1969 Posted : 12 April 2018 22:09:39
The hatch from above.
Sticky Wickett
#1970 Posted : 12 April 2018 22:15:44
Looking forward.
There are small etched pieces that make up the hinges that attach to the hatch, but I've decided to fit these at a later date whilst I had handle the boat during this stage.
I also have to turn the boat upside down and rest it on the planking while I fit the rudders, fore and aft planes, prop shafts and propellers. Only when these components are fitted can I then upright the boat and fit all of the small, casing details including cleats, eyelets, the hinges as mentioned previously and the capstan.
Sticky Wickett
#1971 Posted : 12 April 2018 22:18:31
The next step was to turn my attention to the aft section of the casing. The first job was to clean up the aft navigation light housing, mark out and drill a locating hole in the casing and test fit for alignment.
The attached photo shows the aft navigation light ready for fitting.
Sticky Wickett
#1972 Posted : 12 April 2018 22:21:31
Aft navigation light housing fitted.
I will fit a small LED into the housing and wire it up at a later stage. The housing is not fixed at this stage; it just provides a footprint to plank around and then be removed until a later date.
Sticky Wickett
#1973 Posted : 12 April 2018 22:24:09
Showing the housing from another angle.
Sticky Wickett
#1974 Posted : 12 April 2018 22:25:00
The attached photo shows the first central plank aligned and glued into place.
Sticky Wickett
#1975 Posted : 12 April 2018 22:28:21
A further central plank fitted.
These act as guides from which all consequent planks are fitted in the construction of the mahogany decking.
Sticky Wickett
#1976 Posted : 12 April 2018 22:32:23
Two sections of planking were then laid either side of the central planks. The housing was then fitted and a scalpel was run around the housing edge. Several passes were required before I had cut through the wood.
The attached photo shows the surplus cut away.
Sticky Wickett
#1977 Posted : 12 April 2018 22:33:27
Housing refitted and further planking laid to make up the decking.
Sticky Wickett
#1978 Posted : 12 April 2018 22:34:05
From another angle.
Sticky Wickett
#1979 Posted : 12 April 2018 22:34:43
Looking forward.
Sticky Wickett
#1980 Posted : 12 April 2018 22:36:35
That concludes this weeks post.
Thanks for looking in, have a great weekend and happy modelling.BigGrin
Phil W.
Guest (13)
This page was generated in 0.397 seconds.
