Me thinks you are too modest Derek  . You're off to a great start, and no doubt a great build. Keep up the good work Gray
Thanks for looking in and the comments. As an aid to gauging the footprint size of this build I`ve constructed one of the figures from the pit crew. (The time keeper) When painted up she will have a timing board and a stop watch. Just primed for now. Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi Del, When i first saw the timekeeper figurine i genuinely thought it was Jimmy Saville Good to see your progress. Keep up the good work Regards Gray
CaptnBirdseye wrote:Hi Del, When i first saw the timekeeper figurine i genuinely thought it was Jimmy Saville Good to see your progress. Keep up the good work Regards Gray Better not give her blonde hair then. Regards delboy271155 ( Derek ) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
delboy271155 wrote:CaptnBirdseye wrote:Hi Del, When i first saw the timekeeper figurine i genuinely thought it was Jimmy Saville Good to see your progress. Keep up the good work Regards Gray Better not give her blonde hair then. Regards delboy271155 ( Derek )
Two more figures today. The team manager, who having primed I can see some seam line still there to be removed and will have timer board and ear defenders added, plus the camera man who will have cameras and camera bag added. These along with some of the boxes and mechanics gear should be enough to work on the footprint size, but that`s a job for tomorrow. Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Nice start Derek, it's going to look great with the figures.
Figures look great Derek and should paint up very nicely....  .. very nice start.... Regards Alan
Great start. Can't wait to see how the figures paint up. Malc.
Hi off to great start,look forward to more,cheers mick. Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Very nice figures Derek, nice addition. Mark Regards Markwarren (Mark) Admin
Great start Derek  the figures will add to the scene. Al
Thanks for all the views/comments. I`m sure the figures will paint up well as the scale should make it easier. I`m experimenting with the tarmac base at this time but this in itself may pose an issue. I have sourced a picture that is freely available on the web that both helps and hinders by build. Help: Accurate picture of the pit crew and their uniforms. Hinder: The pit surface doesn`t look like tarmac,I`m sure its some form of concrete. More investigation required. All adds to the fun. Until next time Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
 I wouldnt worry too much about the pit surface makeup/colour Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi all, This is the diorama set-up update bit. Nothing fancy, an old bit of foam for the base and figures set in place by bits of cocktail sticks.  Some figures needed just one cocktail stick but those that are leaning over need two. Pic 1 shows the cameraman with stick attached, this not only helps in the dio set-up, but also with the painting as you can hold the stick and paint and then leave to dry with the stick stuck into a piece of balsa or foam. Pic 2 is the full set-up, I again apologise for the base but it was the right material and close to the correct size. Pic 3 Shows the Manager and wheelman Pic 4 Shows the Jack man - not sure if he`ll be at the front or back yet, along with the wheelman and team manager but it won`t affect the layout size so that can be decided a bit later. Pic 5 Shows the cameraman and engine tuner. and Pic 6 Shows the impatient driver and the time keeper. With the driver out of the car the quote of the team manager will be "We only have an hour practice time left" So the dio base will be approx 26" x 16" plus the fancy edging. Until next time Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
 Looking good Derek and very busy when completed Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Nicely done Derek, plenty of scope for detailing..... Regards Alan
Making some nice progress Derek  will make an interesting scene once all the details are added. Al
Nice work Derek, this is going to look so good when complete. Mark Regards Markwarren (Mark) Admin
It's going to be an interesting dio, I look forward to seeing it progress.
