I see your problem jack. looks like it could have done with a filler bloc perhaps?. if you are waiting ten I would build up with wood and sand back into shape. some ships did have black hull so you could got either black or white Jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Joined: 28/05/2014 Posts: 938 Points: 2,823 Location: Milan (Italy)
Monday 26 March 2018Here below some additional images of the model . . same day of previous message. Regards, Jack.01 Ragusian Carrack/25032018/IMG_20180325_122538.jpg  01 Ragusian Carrack/25032018/IMG_20180325_122555.jpg  01 Ragusian Carrack/25032018/IMG_20180325_122546.jpg A nice present made of beers from Stockholm, hope they are good as beauty. I'll let them stand some days because of the journey and then . . . prosit.01 Ragusian Carrack/25032018/IMG_20180325_184115.jpg
Thursday, April 5th, 2018The first planking is now definitely complete. The following three images show a small groove still to be closed in the connection between the hull and the forecastle. It is now closed but I didn't shoot other photos for such an insignificant detail. Now it is a matter of sanding and smoothing the whole hull to level the small differences in height between some strips and adjust a batch of small depressions in the lower area, below the WL, at the bow.01 Ragusian Carrack/28032018/IMG_20180328_195638.jpg  02 Ragusian Carrack/28032018/IMG_20180328_195722.jpg  03 Ragusian Carrack/28032018/IMG_20180328_195757.jpg While I'm waiting to get the will to breathe some sawdust, I proceeded to complete the second planking, with cherry veneer, on the transom. Three images of the final result follow here below.04 Ragusian Carrack/05042018/IMG_20180405_160542.jpg  05 Ragusian Carrack/05042018/IMG_20180405_160449.jpg  06 Ragusian Carrack/05042018/IMG_20180405_160225.jpg See you next time, even if I have a garden table with two chairs, a bit ruined by sun and rain to be repaired: sanding, a couple of paint undercoats and a final coat of clear paint with wax effect. This is to say that you probably shouldn't expect too many news soon. Greetings, Jack.
nice looking build and a good update. Cheers Rich
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,277 Points: 22,138 Location: Northamptonshire, England
That’s some great work there Jack. Mark Regards Markwarren (Mark) Admin
Looking good there Jack  great stuff  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Sunday 8 April 2014Since I do not expect to have many things to show soon, I decided to discuss some aspects related to the finishing of the first planking, task mandatory to prepare the hull to receive the second planking. I remember that this second layer will be applied using strips from veneer of cherry wood.
Now let's clarify better: once you have applied all the strips of the first planking, you need to smooth the hull because you will discover a lot of imperfections, some of them of very little importance but also some problems that could affect the subsequent tasks and the expected results. Usually in this phase we'll work with sandpaper and sanding blocks to smooth and level the entire hull. In the worst cases using even some kind of putty.
One of the problems that occurs very often is the fact that two or more planks, placed side by side, are not properly aligned assuming the form of steps. They may be originated for different reasons, for example for a different thickness of the strips, maybe only for few tenths, or a curvature slightly different and so on. Regardless of the reason, during the finishing phase after the planking, you must resolve these aspects to get at the end a perfectly smooth hull, without steps, bumps or dips.
The solutions for leveling these steps are substantially two: 1) lower the area of the most protruding strip to bring it to the same level as the deeper one or 2) fill the area of the most hollow strip to bring it to the level of the most protruding. In the first case it's a matter of sanding one strip in order to remove the excess part, in the second it is necessary to fill the missing part with a filler. Regarding the solution to be adopted from time to time there aren't precise rules, it's our sensitivity, experience and knowledge of how we have applied the plank. However, most frequently, we will use both methods because these differences in height are very, very common.
Well, I have written that in the case of the solution #1 it is sufficient to smooth the affected area to achieve the result, while in the case #2, once the points to adjust are properly identified, we can choose between a) use putty as filler or b) glue some wood, in the form of strips of adequate thickness, in the area to be filled and then level it by sanding.
Photos #01 and #02 here below show on the hull of my carrack some areas, highlighted with a pencil, where you need to apply the filler. Thanks to the high contrast of the images in daylight, many other areas with steps are also visible. If not marked with the pencil, it means that I have decided to use the #1 solution. After a preliminary roughing, I sat in a well lit area and proceeded to identify these critical areas and to highlight them, marking their right positioning.
It's all for today, see you next time. I beg your pardon for my english, greetings, Jack.01 Ragusian Carrack/07042018/IMG_20180407_105523.jpg  02 Ragusian Carrack/07042018/IMG_20180407_105529.jpg
Looking great, so is your weather 😎 “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Very nice work, should look a lovely model when complete
Monday 9 April 2014Now it's a matter to apply the filler. Personally I try to avoid using putty and I prefer to use wooden strips as a filler.
For this purpose I have a supply of sweetwood strips of 0.5mm thickness which is usually good for almost all cases. The strips must be the same height as those used for the planking.
I cutout a piece of strip with the length of the area to be filled, then, using the cyanoacrylate glue I paste it in place and move to another area until the operation is completed on all the previously highlighted parts. At this point, I cover these areas with a coat of vinyl glue diluted 50% with water. In this way I soak the strip and fill all the outer edges with glue. This operation adequately fixes the batten to the hull even in the most remote areas ensuring a bonding that covers 100% of the area ensuring a perfect seal. Images #03 and #04 show these strips applied and before the next sanding phase.
I let, for safety, spend a day to dry and then I move to smooth the part of the wood strip in excess. At this point the problem is 99% solved. Once polished with ever finer abrasive paper, I proceed to stabilize the area by reapplying a second coat of diluted vinyl followed a few hours after by a slight smoothing with a fairly fine abrasive paper. In the most difficult cases only at this point I consider the application of a small amount of putty.03 Ragusian Carrack/07042018/IMG_20180407_115552.jpg  04 Ragusian Carrack/07042018/IMG_20180407_115602.jpg PS: This technique can also be used to fix areas of the hull where there are slight dips. Photos #05 and #06 show two of these areas in the bow area in which I have implemented this technique. I think, instead, that for the bumps there is only one solution: prevent their formation by checking well the course of the plank before applying it.05 Ragusian Carrack/07042018/IMG_20180407_115608.jpg  06 Ragusian Carrack/07042018/IMG_20180407_115625.jpg In the next message I will go on to show the result obtained when processing is finished.
Friday, April 16th, 2018Today, let's try to complete the speech interrupted a few days ago, relating to the removal of the gaps between a plank and its adjacents without using putty.
Once the preliminary tasks have been completed (glueing strip segments, fixing them with diluted vinyl glue, etc.), we proceed by sanding these sections to level them to the other parts of the hull.
It is advisable to work gently, avoiding to use coarse grained sandpaper. It is important to use only sanding blocks, avoiding, until the desired result is achieved, the use of abrasive paper only with hands.
The first two images show the work almost finished when this technique is used to eliminate the differences in height between one strip and another: depending on the height of the gap, the piece will be more or less thin, so that in some points the signs made with a pencil, to delimit the area, may appear, while in others not.01 Ragusian Carrack/13042018/IMG_20180413_183457.jpg  02 Ragusian Carrack/13042018/IMG_20180413_183512.jpg In the next two images, instead, we see the results when using this technique to fill in depressions on the hull. Here the papersanding technique, although very similar, is slightly different but with a little practice and intuition you may easily learn how to proceed.03 Ragusian Carrack/13042018/IMG_20180413_183432.jpg  04 Ragusian Carrack/13042018/IMG_20180413_183520.jpg Finally, an image from a particular perspectiv where it is possible to notice how the two slight depressions that were present are now disappeared. This is appreciable by observing the correct curve on the hull.05 Ragusian Carrack/13042018/IMG_20180413_183540.jpg Finally, as last step, a new coat of diluted vinyl glue over the areas where we worked on and, when the mixture of water and glue will be perfectly dry, a light refinement with very thin abrasive paper to completely smooth the whole. To speed up drying and waste little time, you can use a hair dryer. Now that we have also fixed these problems we can move on to the final hull sanding which from now on becomes an ordinary matter, made of patience and sawdust. In some cases we could fill some small grooves in certain points of the hull with putty, but usually, having to apply above a second planking, this operation is not strictly necessary and could even be bypassed.
A friendly goodbye, Jack.Aubrey.
Thursday 3 May 2018
In view of my return to Cinisello Balsamo, planned for Friday, May 11th after eight months in Tuscany, I packed all the necessary material for the Ragusian Carrack I have here in Pisa. But, as the old italian proverb says, "the devil makes the pots but not the lids", and so a unplanned problem was born that forces me to postpone my return, probably until mid-June.
Consequence of this is that I am forced to keep the shipyard closed for longer than I thought, so do not expect further progress on this log for some time, at least until the second half of June.
Best regards, Jack.
Hi Jack May I wish you a smooth transition and look forward to the point of time where you can re-start your build diary. I am finding this one a unique and interesting build and a pleasure to follow. Happy building David
daffy09 wrote:Hi Jack May I wish you a smooth transition and look forward to the point of time where you can re-start your build diary. I am finding this one a unique and interesting build and a pleasure to follow. Happy building David Thankyou very much, David. Hope to be back asap. Jack.
I hope all is well with you and yours Jack, will be looking forward to your next update. Regards Paul Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Friday, September 14th, 2018
Hi friends,
After a long absence from this forum and shipmodeling in general I'm now, finally, free to restart the "Ragusian Carrack" shipyard.
I stopped shipmodelling beginning of May and I'm trying first to define a preliminary activity plan: I've forgotten a lot of issues and so I need to replan the next task of the project.
As soon as possible I'll resume posting on this forum.
Regards, Jack.Aubrey
jack.aubrey wrote:Friday, September 14th, 2018
Hi friends,
Regards, Jack.Aubrey Cool looking forward to more build pics Jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Good to hear more of this one coming soon. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Great to know you're getting back on track again, I've been missing this build and looking forward to its continuation. Happy building David
Tuesday 18 September 2018Finally, after months of total inactivity, on Monday, September 17 I started working again . . The work is now aimed to prepare the hull to receive the second planking: there is to perform the final sanding of the hull but also many other minor tasks that must be started before applying the second layer. I therefore focused on the prow and the foredeck, where there is still much to do. To begin I refined all the details left rough on the foredeck. 01 Ragusian Carrack/19092018/IMG_20180919_102258.jpg  Then I started to prepare the grating at prow by assembling the elements supplied in the Marisstella kit and then joining them together to form a surface suitable for the required shape. In the picture below the composite of the grating and the template that will serve to shape the finished piece. 02 Ragusian Carrack/19092018/IMG_20180919_102221.jpg Thursday 20 September 2018Having in mind the latest photos of the central area of the model I took months ago, it is clear that the new details added and visible in the picture below should be applied now, so as to cover them with the second planking. The pre-cut pieces have been modified to adapt them to my model. 01 Ragusian Carrack/20092018/IMG_20180920_162148.jpg  I then finished the prow grating, shaped appropriately and finally I fixed it in position . . but there is still a lot to do, so the situation here is still evolving. 02 Ragusian Carrack/20092018/IMG_20180920_162310.jpg  03 Ragusian Carrack/20092018/IMG_20180920_162136.jpg  04 Ragusian Carrack/20092018/IMG_20180920_162121.jpg  That's all for now, though not much. See you next time, Jack.Aubrey.
