2 Pages 12>
USS Nameless Options
budgie
#1 Posted : 07 April 2018 11:19:03
BigGrin Hi Folks
Have ended up being more or less housebound for the next few weeks due to a broken ankle.
Not wanting to fall into a routine of daytime television viewing I decided to have a go at building a model again to help pass the time and occupy my mind.
I opted for a card model of a 1/200 scale USS Missouri giving an overall length of 135cm from eBay
(made a great saving than buying from a shop)Cool
Decided to call this topic USS Nameless therefore allowing me to make changes for personal taste and lack of skills
The frame templates were photocopied at 104% changing the scale to 1/192 for perhaps obtaining fiddly fittings from retailers and mainly helping with my eyesight
The templates were glued to 1.5mm board using Elmers Rubber Cement (no wrinkles on paper) then cut out
Requiring a flat surface I used an old mirror (keep jumping back every time I go near it) and with the aide of some metal bars, magnets and set squares I made a start.
Crying Oops need to go now the Jeremy Kyle Show is about to start
budgie attached the following image(s):
CaptnBirdseye
#2 Posted : 07 April 2018 12:27:19
Rank: Superelite
LOL BigGrin LOL i’m Sure your build will be much more interesting than daytime tv !
Good luck with your build. It will be interesting to see what you do with her Cool
Gray
daffy09
#3 Posted : 07 April 2018 13:26:19
Hi Budgie
Nice to see another card model being built here. We haven't seen one for a long time and I look forward to watching this one come together.
P.S. Who's Jeremy Kyle anyway? lol
Happy building
David
TRGRichie
#4 Posted : 07 April 2018 15:41:03
I'll be following this build as I have an itch to build a paper/card model, you might be the inspiration I need to finally do it
Cheers
Rich
AUTO FRUMP STOMPER
#5 Posted: : 07 April 2018 15:52:02
Look forward to seeing USS Nameless take shape Cool
#6 Posted : 07 April 2018 17:52:11
BigGrin Nice to see a card model on the go, will be watchingCool
#7 Posted : 07 April 2018 19:32:28
Nice to see you back building again BigGrin
#8 Posted : 07 April 2018 22:51:37
Hi Nice to see you building somthing a bit different
Will be following
#9 Posted : 08 April 2018 00:42:53
Great to see a card model going. I started one a few years ago but never got too far with it. I've got another in the cupboard to do. They are certainly a different challenge to wooden or plastic kits.
Ive started this one and have it stored for future. I got the mast set to go with it as you don't get them.
https://www.ebay.co.uk/i...66cm-long-/232704176990
plus another shipyard one in the cupboard.
The only essentials you need are The old type razor blades for cutting, and glue. I used 2 types of glue, the general pva glue and Tacky glue(hobbycraft i think) its thicker and very sticky so will hold parts in place until dry. Works a dream on smaller parts.
ChrisCool
budgie
#10 Posted : 09 April 2018 09:48:51
BigGrin Hi Folks thanks for popping' in
@Rich below link may give you inspiration to have a go
http://www.papermodelers...fuso-1-200-hal-gpm.html
Progress so far: superglued a strip on hull to keep frames square and make more rigid.
This is 1.5mm card which is out of spec of the card supplied (hence USS Nameless)
If I used the thickness of card supplied, the card would sag between frames unless you fit several hundred formers between the framesCrying
Started the forward frames
budgie
#11 Posted : 10 April 2018 11:04:22
BigGrin Morning' Folks
progressing working aft
daffy09
#12 Posted : 10 April 2018 15:08:33
Hi Budgie,
I'm impressed with how quickly you're progressing with the skeleton of the hull, nice going. Had a look at that link you posted and I must say how much I am in awe of the skill and patience of these guys who can build with such detail. Do you know if all those parts are made from card, or are they additional extras that have to be purchased separately?
Happy building
David
budgie
#13 Posted : 10 April 2018 20:56:11
daffy09 wrote:
Hi Budgie,
Happy building
David
Hi David
most of it looks like its made from the card supplied with separately purchased brass wire used to substitute the hand rails etc
Cool To make things easier you can use brass or styrene rod for the smaller gun barrels and such like.
(and in my case the big barrels too and prop shafts)
You can substitute the card for any material that you prefer
Crying When you cut the card you will have white edges which should be painted to blend in with the unit you are building.
Cool You can photocopy the card and stick it to scrap cardboard from cereal boxes etc to practice making the part as many times as you like and if happy with result just paint the unit.
BigGrin Thanks for lookin'
daffy09
#14 Posted : 10 April 2018 23:15:44
Thanks for the info Budgie, that was useful. I like the idea of photocopying the parts to practice the assembly - good one.
Happy building
David
Gibbo
#15 Posted : 10 April 2018 23:43:33
Just had a look through the link you put up on the paper modeler, jeez and i thought Jase had it tough with his etch, remarkable.
Paul
budgie
#16 Posted : 15 April 2018 15:53:22
BigGrin Hi Folks
carrying on toward the aft section a couple of frames caught my eye, Bored didn't look right
Crying The distance between the frames on the stb side was different than on the port side
Not by much but....
Cursing oooooh maybe should have used a jig
Blushing Decided to start again following the instructions this time using styrene in place of cardboard
Again paper templates stuck to styrene and cut out (score and snap)
Did not want to stick parts on top of the paper so the paper strips were removed where keel and frames get glued together
I opted for super glue rather than plasweld as I have tried that before and being over generous with applying the plasweld when i turned it over found the styrene had melted misshaping the false deckLOL
budgie
#17 Posted : 15 April 2018 15:57:09
BigGrin carrying on working aft on the lower hull parts
#18 Posted : 15 April 2018 22:41:53
Looks to me like you're making excellent progress with this one Budgie. Have never thought of trying a card model, will be following yours with a great deal of interest.....Cool Cool
#19 Posted : 17 April 2018 14:52:25
Nice work so farBigGrin regards PhilCool
Gibbo
#20 Posted : 17 April 2018 16:05:10
Looking very neat and tidy, and some great tips to boot, really enjoying watching this,
Paul
2 Pages 12>
This page was generated in 0.796 seconds.
