106 Pages «<9899100101102>»
DaDokta
#1981 Posted : 13 April 2018 07:07:52
Another nice update!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
Sticky Wickett
#1982 Posted : 13 April 2018 09:27:39
Thank you Walter for looking in!Cool
Phil W.
#1983 Posted : 13 April 2018 11:22:59
It is a pleasure to watch Phil BigGrin i`m going to re-starting mine as soon as i`ve completed the Lancaster BigGrin regards PhilCool
Sticky Wickett
#1984 Posted : 13 April 2018 12:52:29
Thanks for looking in Phil. Appreciated!Cool I'm glad you're restarting yours. I'll check your Lancaster build diary.BigGrin
Phil W.
#1985 Posted : 13 April 2018 13:05:17
Hi Phil.
The decking looks stunning. really finishes off the top of the submarine.Cool Drool Drool BigGrin
Sticky Wickett
#1986 Posted : 13 April 2018 14:12:10
ian smith wrote:
Hi Phil.
Hi Ian, thank you very much!Cool It really transforms it.
Phil W.
#1987 Posted : 13 April 2018 16:44:18
BigGrin The decks make all the difference, looking goodCool
kpnuts
#1988 Posted : 13 April 2018 20:39:57
Man this is so awesome.
#1989 Posted : 13 April 2018 21:46:22
Top notch work, she looks great.....Drool Drool
Sticky Wickett
#1990 Posted : 16 April 2018 09:38:46
Thanks very much Andy!Cool
Phil W.
Sticky Wickett
#1991 Posted : 16 April 2018 09:39:16
Glad you like it Ken!Cool
Phil W.
Sticky Wickett
#1992 Posted : 16 April 2018 09:39:40
Thank you very much Alan!Cool
Phil W.
Sticky Wickett
#1993 Posted : 19 April 2018 21:15:42
This weeks update of my U230 U-boat build continues with laying mahogany planking on the aft casing.
The attached photo shows a mahogany plank being marked out for length.
Sticky Wickett
#1994 Posted : 19 April 2018 21:19:16
The marked out plank was then cut, ends gently filed and glued in place.
The attached photo shows the plank glued down and the gap being checked with a 0.25mm spacer [scrap off cut LOL ].
Sticky Wickett
#1995 Posted : 19 April 2018 21:20:30
This photo shows the plank located in place with an even 0.25mm gap between it and it's neighbour.
Sticky Wickett
#1996 Posted : 19 April 2018 21:20:58
From above.
Sticky Wickett
#1997 Posted : 19 April 2018 21:21:39
Two shorter planks fitted.
Sticky Wickett
#1998 Posted : 19 April 2018 21:22:16
A further two, short planks fitted.
Sticky Wickett
#1999 Posted : 19 April 2018 21:23:42
This photo shows a small off cut of mahogany being test fitted using tweezers to help locate it.
Sticky Wickett
#2000 Posted : 19 April 2018 21:24:10
From another angle.
This page was generated in 2.630 seconds.
