Paints Options
Jackbern
#1 Posted : 24 April 2018 19:43:17
Good Evening.
I have been looking at the list of paints that Gandale has put up that are used for the Vasa build.
Thank you for doing this. It will be a great help.
One question which Burnishing Fluid do you use. I have looked at a few but not sure if I am looking at the wrong item as they seem to be for Model Railway tracks.
Any help would be appreciated.Confused
Jackbern
#2 Posted : 24 April 2018 20:00:41
Krick blackening fluid is one brand available from CMB and other suppliers..
https://www.model-dockya...Chemical_Blackener.html
A “how to” here..
http://forum.us.model-sp...aspx?g=posts&t=5468
But there are also others for other metal types, scroll down to “Metal Blacks” in this link..
http://www.finescale.org...n&information_id=27
Be mindful that the brass plate on plated brass parts can be dissolved by blackening fluid, to leave the underlying metal type, where you may then need to use a different blackening fluid type.
Jackbern
#3 Posted : 24 April 2018 20:23:53
Many thanks for the information Tomick.
The links you posted helped me a lot.
Now just need to get an order in.
Jackbern
This page was generated in 0.093 seconds.
