106 Pages «<100101102103104>»
Sticky Wickett
#2021 Posted : 26 April 2018 22:00:28
From the side.
Sticky Wickett
#2022 Posted : 26 April 2018 22:01:50
Another shot showing the decking completed so far.
Sticky Wickett
#2023 Posted : 26 April 2018 22:02:46
This photo shows further decking fitted to this particular section.
Sticky Wickett
#2024 Posted : 26 April 2018 22:03:25
View from the aft navigation light housing.
Sticky Wickett
#2025 Posted : 26 April 2018 22:03:58
All decking completed for this section. View from the port side.
Sticky Wickett
#2026 Posted : 26 April 2018 22:05:25
From above.
Sticky Wickett
#2027 Posted : 26 April 2018 22:05:55
Looking forward.
Sticky Wickett
#2028 Posted : 26 April 2018 22:08:17
Looking at the decking from casing level.
Sticky Wickett
#2029 Posted : 26 April 2018 22:13:06
That concludes this update on fitting the decking; slow and steady at the moment, but progress nonetheless.
Thanks for looking in, have a great weekend and happy modelling!Cool BigGrin
Phil W.
Sticky Wickett
#2030 Posted : 02 May 2018 23:03:05
To be honest, I haven't done that much this week. I've found it goes like that sometimes, especially on a long haul project.
This post continues with laying the mahogany planking to form the decking on the aft casing.
The attached photo shows several small pieces cut to length and ready for fitting.
Sticky Wickett
#2031 Posted : 02 May 2018 23:03:55
The first of these small pieces laid down along the centre line.
Sticky Wickett
#2032 Posted : 02 May 2018 23:04:31
Double checking it's aligned centrally.
Sticky Wickett
#2033 Posted : 02 May 2018 23:05:43
A small filler piece, cut to length, glue applied and ready for fitting.
Sticky Wickett
#2034 Posted : 02 May 2018 23:06:49
A small section completed with the pieces I mentioned before.
Sticky Wickett
#2035 Posted : 02 May 2018 23:07:27
Even smaller pieces, laid out and glued in place.
Sticky Wickett
#2036 Posted : 02 May 2018 23:08:37
Cutting a piece to connect two sections, running along the right hand side of the casing locker.
Sticky Wickett
#2037 Posted : 02 May 2018 23:09:24
A similar length of mahogany fitted to the left hand side of the casing locker.
Sticky Wickett
#2038 Posted : 02 May 2018 23:11:08
This photo shows a thin piece of mahogany cut length ways so that it fills the gap between the casing locker and the next plank.
Sticky Wickett
#2039 Posted : 02 May 2018 23:12:15
Similarly, a piece was cut length ways to fill the gap on the left hand side of the casing locker and the next plank to it.
Sticky Wickett
#2040 Posted : 02 May 2018 23:15:37
Well that concludes this weeks very short update. I'm hoping to close this part of the build out next week by finishing the last section.Blink
After that I will be buying a donor model to take measurements of the conning tower and transfer those onto mine so that it resembles a 'type IV' tower.Cool
Thanks for looking in, have a great bank holiday weekend and happy modelling!BigGrin
Phil W.
Guest (11)
This page was generated in 0.521 seconds.
