Fighting top hand mast Options
saintsman123
#1 Posted : 18 June 2011 12:22:15
I found getting the dowel to stay in place between the two end blocks a bit difficult, so came up with this idea, which may or may not help others.
I just used the "Bitt" method, drilled a .7mm hole in the centre of the end pieces of wood, and stuck a cut off nail in each block, (keeping the point very small) I then pushed the end blocks onto the small dowel, this kept everything together nice and centrally and allowed the glue to dry without the dowel moving.
As I say it may or may not help others but it's just an idea which worked for me
Come on you Jimmies
underhill
#2 Posted : 24 June 2011 14:58:30
Rank: Amateur Level 1
Thanks for that, I was finding it a bit tricky as well. I usecd pins for the columns as well that helped keep them in place
This page was generated in 0.026 seconds.
