106 Pages «<102103104105106>
Sticky Wickett
#2061 Posted : 10 May 2018 19:49:58
From above.
Sticky Wickett
#2062 Posted : 10 May 2018 19:50:56
This photo shows the completed decking along the full length of the U-boat.
Sticky Wickett
#2063 Posted : 10 May 2018 20:02:12
A while ago I mentioned that I would have to buy a donor model so that I could measure the conning tower, convert the measurements and scratch build modifications to my existing conning tower to correctly reflect U230 from 1942 onwards.
The donor model was ordered last week and arrived on Tuesday. A Revell 1/72 Type VIIC/41 Atlantic [limited edition]. This version has the modified conning tower, so looking forward to starting this stage of the build!BigGrin
Revell also make a 1/72 Type VIIC 'Wolf Pack'. This version has the correct conning tower for U96 and U552 [Trumpeter model], but not U230.
I'll go into more detail about this kit next week and look at the parts I will be measuring and making notes on.
See attached photo of the box art.
Sticky Wickett
#2064 Posted : 10 May 2018 20:08:40
That concludes this weeks update and completion of the mahogany decking.BigGrin
Thanks for looking in, have a great weekend and happy modelling.
Phil W.
kpnuts
#2065 Posted : 10 May 2018 20:55:09
Decking looks great you certainly are a master builder
Sticky Wickett
#2066 Posted : 11 May 2018 09:31:45
Thank you very much Ken!Cool That really is a great compliment and much appreciated!
Phil W.
#2067 Posted : 11 May 2018 13:16:36
You`ve done an excellent job on the decking PhilBigGrin regards PhilCool
Sticky Wickett
#2068 Posted : 11 May 2018 13:35:16
Thanks very much Phil.Cool Another job complete on this project. 7.5 weeks to finish the decking!Blink Blink
Phil W.
Sticky Wickett
#2069 Posted : 17 May 2018 21:38:36
This weeks update sees a closer look at the 1/72 scale donor parts, measuring these parts and converting those measurements to 1/48 scale for my conning tower modification.
The attached photo shows the box opened revealing the two halves of the pressure hull.
Sticky Wickett
#2070 Posted : 17 May 2018 21:42:32
The 1/72 scale port side pressure hull against my 1/48 scale U-boat pressure hull. Needless to say the 1/48 scale is a beast. It weighs a fair bit now; roughly 4 to 5Kg's!Blink
Sticky Wickett
#2071 Posted : 17 May 2018 21:43:13
Close up of both port bows.
Sticky Wickett
#2072 Posted : 17 May 2018 21:44:14
Photo taken slightly further back to highlight the difference in size.
Sticky Wickett
#2073 Posted : 17 May 2018 21:45:17
Photo shows several bags of parts.
Sticky Wickett
#2074 Posted : 17 May 2018 21:50:17
This photo shows the 1/72 scale conning tower base next to the 1/48 scale version. It's this base that I will start with on this modification.
Sticky Wickett
#2075 Posted : 17 May 2018 21:51:01
From another angle.
Sticky Wickett
#2076 Posted : 17 May 2018 21:55:20
With snips i carefully removed the two halves of the donor conning tower from their sprues and cleaned up these areas with a craft knife ensuring they were smooth.
Sticky Wickett
#2077 Posted : 17 May 2018 21:58:20
I then used masking tape to hold the two halves together. I'll be looking to sell this kit once I've obtained all the measurements, so i'm taking extra care with these parts. No glue involved, keeping the parts damage free.
Sticky Wickett
#2078 Posted : 17 May 2018 22:01:06
Photo from above showing the compound curve of the conning tower bases. My 1/48 scale version isn't too far out considering I only used photos, but still, a little work required to get that curving conning tower base spot on.
Sticky Wickett
#2079 Posted : 17 May 2018 22:04:49
Looking at both conning towers from the front. You can see that the 1/72 scale version not only curves to a point at the rear but also the sides taper out along its length. In another update i'll make formers that match the tapered angle of the donor model and use them for fixing the tower sides.
Sticky Wickett
#2080 Posted : 17 May 2018 22:05:46
In this photo you can see the tapered tower sides.
This page was generated in 0.572 seconds.
