Jaguar E series color Options
el_jalepeno
#1 Posted : 14 May 2018 20:39:27
Rank: Beginner Level 1
New here and just ordered my subscription (hopefully I can wait for each month's parts, but looks like the spoked rims will keep me busy enough!).
Here's my question: Has anyone repainted their car a different color from the Racing Green? My dad used to have a silver Jaguar XKE, and I was interested in possibly repainting mine.
Any insight would be appreciated.
Thanks!
#2 Posted : 14 May 2018 21:11:24
Hi and welcome to the forum
As for the paint job if you treat the parts like a real car would be painted you will get a top finish. Strip the old paint and undercoat then rub down and undercoat again to get a smooth finish. This can be done as many times as you like to get a good finish.
In the UK we can get zero paints that are formulated for model cars and they do jaguar E type colours, link below;-
https://www.hiroboy.com/...ml--product--10083.html
After the silver has had the same treatment as the undercoat you will need a good gloss coat again Zero do a diamond coat that when applied will look like your about to fall into it. Link below:-
https://www.hiroboy.com/...ml--product--10301.html
Whatever paint you choose good luck with the build I have also added a couple of links to models I have built using the above paint so you can see the results that can be obtained.
http://forum.model-space...spx?g=posts&t=24723
http://forum.model-space...spx?g=posts&t=25311
#3 Posted : 14 May 2018 22:18:36
Welcome to the forum. I look forward to seeing your progress soon.
el_jalepeno
#4 Posted : 14 May 2018 23:33:49
Thank you, both!
#5 Posted : 14 May 2018 23:46:04
Welcome to the forum. BigGrin
Would be nice to see you start a diary of your work so we can see how you get on.
This page was generated in 0.740 seconds.
