Rossi Yamaha YZR-M1 Official Build Diary - Pack 2 (USA) Options
#1 Posted : 15 May 2018 18:21:42
Pack 2 contains parts for Stages 5 - 8
Stage 5
Contents: Front fender, Right front brake disc.
There is no construction at this stage.
Stage complete, carefully store any remaining parts in a stage labelled bag.
#2 Posted : 15 May 2018 18:22:47
Stage 6
Contents: Left front fork, Left front brake caliper, Bracket.
Before proceeding, you should perform a test on the fork. Hold the wider part in your hand and press the smaller part into it. You should feel resistance as you do this. When released, the smaller part should return to its original position.
#3 Posted : 15 May 2018 18:23:53
Stage 7
Contents: Left front wheel bracket, Bracket cover, Rear bracket cover, Valves, Gas cartridge, Type B screws, Type C Allen screws, Allen key.
Taking the bracket cover and the rear bracket cover, identify the two small pins on the cover indicated by the arrows.Insert the pins on the back cover into the holes in the bracket cover, and press the parts together.Preparing the gas cartridge and the left front wheel bracket,insert the cartridge pin into the hole in the bracket.Position the valves into the two notches in the bracket as shown, you can fix the valves in place with superglue.Placing the two
assemblies in front of you, insert the posts of the cover into the matching holes in the bracket, and press the two parts together.
#4 Posted : 15 May 2018 18:27:17
Stage 8
Contents: Right front fork, Right front caliper, Bracket.
Using the front fork supplied with Stage 6 and the bracket completed in Stage 7,insert the lower end of the fork into the hole in the bracket and secure the bracket to the fork with a screw. Position bracket C
over the assembly, aligning the holes of both parts, and securing them with a type C Allen screw.
You can view the official video build for this pack here
https://www.youtube.com/...JUIkfyoZco-rCEsGom94e6WX
This page was generated in 0.297 seconds.
