2 Pages 12>
Martyn's Cook 250 build Options
#1 Posted : 18 May 2018 14:20:15
Martyn's Cook 250 Endeavour 4 pounder cannon competition build entry
Just received my cannon kit . Don't know what I going to do with it yet but got a few ideas Confused
Good luck everyone
Martyn
TRGRichie
#2 Posted : 18 May 2018 14:46:17
Good luck Martyn
Rich
AUTO FRUMP STOMPER
#3 Posted : 18 May 2018 14:58:13
Good luck MartynBigGrin regards PhilCool
#4 Posted : 18 May 2018 16:29:13
Good luck Cool
#5 Posted : 18 May 2018 23:08:41
Good luck Martyn, am sure whatever you do will be up to your usual high standards.... will be watching....Cool Cool
#6 Posted : 19 May 2018 12:26:24
Best of look with your entry
Sticky Wickett
#7 Posted : 21 May 2018 11:49:30
All the best in the Cook 250 comp Martyn!Cool
Phil W.
#8 Posted : 02 June 2018 07:42:21
BigGrin Thanks for the support guys Cool
I made a start on this build last night Cool the gun was cut out and dry fitted to gage the size for the deck it's going to sit on Cool . The deck was made up out of some 3mm light ply and some spare decking planks Cool . While it was drying I started gluing the gun together Cool . I found the wheels stuck out to far from the carriage so adjusted the axles. Next job fitting the barrel and trunnions to the carriage . I have left the trunnions a bit long but will trim them to size later. Today I plan to make the gunwales on the front of the deck Cool
Thanks for looking
Martyn
Martyn Ingram attached the following image(s):
#9 Posted : 02 June 2018 08:04:08
Great start Martyn.Cool
#10 Posted : 02 June 2018 08:16:23
Great startCool
arek
#11 Posted : 02 June 2018 09:09:18
Nice start! ThumpUp
I will also work later in the evening on the deck and gunwales. Noticed same thing about wheels. I do not know what wood the carriage is made of but it is not easy to work withBlink
Arek
#12 Posted : 02 June 2018 11:26:18
arek wrote:
Nice start! ThumpUp
Arek
Hi Arek the carriage is made of walnut ply and are very delicate Blink but quite easy to sand and file Cool
I have just started making up the gunwales so hopefully post some pics later Cool
Catch you later
Martyn
#13 Posted : 02 June 2018 11:39:34
Nice start Martyn BigGrin regards PhilCool
#14 Posted : 02 June 2018 22:43:06
Nice piece od decking for the display looking forward to your buid
Sticky Wickett
#15 Posted : 04 June 2018 12:35:26
Nice start there Martyn.
Phil W.
#16 Posted : 09 June 2018 07:30:14
BigGrin Cheers for the feedback guys Cool
Lots of work done on the 4pdr the bulwarks have been fitted to the deck and a few bits and pieces glued to the side Cool along with the eye bolts for the tackle.
The gun was finally attached to the carriage and the trunnion caps fitted. Next job placing the eye bolts in the right position and making the breaching rope . The rope was made with my ropewalk to get the right thickness. It was then fitted to the rear of the gun . A small bit of card was cut out and painted silver to look like lead that cover the touch hole on the real gun
Next step making the blocks for the outhaul and Inhaul tackles. The blocks were made off 1x1mm walnut strip. A hole was drilled through and small hooks fitted. The blocks were then fitted to the deck and gun eye bolts and the gun lined up with the gunports . The blocks were then rigged and a small ring was fitted to the breaching rope eye bolts and the rope past through and attached to the eye bolts on the bulwark. Once happy the gun was glued down and a small peace of thread was glued on to hold the lead cover down. Some rope was wrapped around a paint brush covered in watered down PVA to make the ropes for the deck. My next job is to do some whethering and making the tools but that's for next time Cool
Thanks for following
Martyn
#17 Posted : 09 June 2018 08:18:44
BigGrin Looking good MartynCool
#18 Posted : 09 June 2018 08:54:27
Excellent work, Martyn.Love
kpnuts
#19 Posted : 09 June 2018 16:49:09
Looking great so far.
#20 Posted : 09 June 2018 19:36:18
Excellent, Cool Cool Cool Cool
2 Pages 12>
This page was generated in 0.192 seconds.
