Hachette 1:8 Scale Fokker Dr 1 Options
TRGRichie
#1 Posted : 20 May 2018 11:19:09
Built this when it was first released by Hachette - she needs a bit of repair now and a clean!
what is the best way to remove dust from models or is it doomed?
TRGRichie attached the following image(s):
AUTO FRUMP STOMPER
#2 Posted : 20 May 2018 16:33:33
That looks wonderful.
Some skilled work went into this i can see.
One of the best ways to get rid of most of the dust is a paintbrush (household type rather than modelling type).
Have a set of "bronzed" ww2 figures that are cying out for a dispkay case so have to resort to the brush more times than not.
TRGRichie
#3 Posted : 20 May 2018 16:43:49
thanks for the reply - I'll try a paint brush.
cheers
Rich
AUTO FRUMP STOMPER
Jackbern
#4 Posted : 20 May 2018 17:01:29
Another good way is to use a hairdryer. This can blow the dust of. Best not to use a high setting.
Jackbern
TRGRichie
#5 Posted : 20 May 2018 17:29:57
Jackbern
...I think I could do some damage if I wasn't careful BigGrin
Rich
AUTO FRUMP STOMPER
#6 Posted : 20 May 2018 19:24:34
for cleaning your models I would recommend a good qulity puffer prush, such as this one.
https://www.amazon.co.uk...URAGADGET/dp/B005NZ3FCM
I genraly use one of these and have the vacuum sucking the dust out of the air
Note the cheap ones on ebay are rubbish and not worth having
GilShapley
#7 Posted : 20 May 2018 19:38:56
I have the exact same model which spends its life hanging from the ceiling in a corner of the dining room. Like you I opted for the "bare bones" and did not attach the red covering. It seemed a shame to cover all the detailed work.
I also have the same problem with cleaning ( SWMBO says its my model and my job to clean) I use an air duster and paint brush
Current Build:-
TRGRichie
#8 Posted : 21 May 2018 07:58:45
Thanks for the cleaning tips guys,
And Gill, great to see another DR1
Thanks
Rich
AUTO FRUMP STOMPER
#9 Posted : 21 May 2018 10:19:35
They both look excellent buildsDrool Drool well done to you bothThumpUp ThumpUp regards PhilCool
#10 Posted : 23 May 2018 14:32:59
Two fantastic builds Well done guys. Cool BigGrin Drool
TRGRichie
#11 Posted : 23 May 2018 18:13:19
Thanks Ian
Rich
AUTO FRUMP STOMPER
This page was generated in 0.602 seconds.
