13 Pages «<45678>»
Anakin Skywalker's Podracer Diorama Options
#101 Posted : 22 May 2018 16:45:47
Very nice work as always Mark, great stuffCool
Andreas
#102 Posted : 22 May 2018 18:23:49
Groups: registriert
That's what I mean, you always learn something new every day,BigGrin Fantastic work, Mark! ThumpUp I love that.!!
Forum Support Team
CaptnBirdseye
#103 Posted : 22 May 2018 20:03:42
Rank: Superelite
Must say Mark you have to have excellent eyesight! All that cockpit detail! Loving it Love
Regards Gray
#104 Posted : 22 May 2018 20:35:41
Very nice work Mark, looking great.
#105 Posted : 22 May 2018 20:55:14
Thank you all for you kind comments.
Gray, I don’t have good eyesight, they are called contact lenses and a very large magnifying glass. Without them I am the real Mr Magoo.LOL
#106 Posted : 23 May 2018 14:22:51
Cool Looking fantastic Mark.BigGrin Drool
#107 Posted : 23 May 2018 22:05:02
Many thanks Ian. Really enjoying this build.Cool
#108 Posted : 23 May 2018 22:17:40
It looks like it and a joy to watch Cool
#109 Posted : 23 May 2018 22:44:13
Stunning work as always Mark, simply love what you're doing with this one.....Drool Drool
#110 Posted : 23 May 2018 22:50:56
Many thanks Alan and Tom.
A little more done this evening. I have some photos of the original prop, and the throttle sticks have some webbing on them as shown in the first picture. I had a hessian sample used for blinds that I thought would come in handy sometime, it’s amazing what I keep, so I used it to bind the shafts.
The last pictures are them test fitted in place.
Thanks for looking.
#111 Posted : 29 May 2018 21:06:49
Cool looks amazing Mark.BigGrin
#112 Posted : 29 May 2018 22:20:55
BigGrin Looking good as always Mark and great workCool
#113 Posted : 29 May 2018 22:29:17
Many thanks Ian, Andy for your comments.BigGrin
#114 Posted : 29 May 2018 22:33:55
Looks great, totaly enjoying your build
Sticky Wickett
#115 Posted : 05 June 2018 12:13:38
Fantastic build Mark!Cool You have an excellent eye for detail. Great build!
Phil W.
#116 Posted : 05 June 2018 12:17:18
This is looking really great.
Keep it coming.
Roy.
#117 Posted : 05 June 2018 13:18:37
Love it Mark, excellent work....Love Love
#118 Posted : 05 June 2018 21:59:47
Many thanks for your comments and support everyone.
A little more done over the last couple of days. I had been looking at the original prop pictures again and saw that the seat was completely different to the one supplied. So, armed with a cutting knife, sanders and some Milliput, I set to.
The first couple of pictures show how it looks on the prop, whilst the remaining ones show my attempt of using the Milliput trying to get a cushion look. I also cut the original chair part down and again filled the holes with the putty.
The final shots show it temporarily in place.
Thank you for looking.
#119 Posted : 05 June 2018 22:40:40
Cool Fantastic work Mark coming along Nicely.Drool
#120 Posted : 14 June 2018 10:49:34
Thank you for your support Ian.
Just a quick update. I have now glued the internal cockpit panels and attached the control throttles. Then, I wired the cockpit lighting, using enamel coated copper wire. This wasn’t as easy as I first thought, as it was a very tight fit and I had to use some blue tack to hold it all in place before attaching the upper half to the base. I have also put a small blob of Bostic UV resin to hold the cable in place, under the seat area, to stop the cable from being pulled through and damaging the internal components.
Once the two halves were attached, I then filled the seams with Vallejo putty. This will be left to dry hard before sanding down to a smooth finish.
More Soon
BigGrin
Guest (7)
13 Pages «<45678>»
This page was generated in 0.974 seconds.
