Very nice work as always Mark, great stuff Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Rank: Pro        Groups: registriert
Joined: 13/03/2012 Posts: 306 Points: 847 Location: Germany
That's what I mean, you always learn something new every day, Fantastic work, Mark! I love that.!!Forum Support Team http://www.model-space.com/de/
Must say Mark you have to have excellent eyesight! All that cockpit detail! Loving it Regards Gray
Very nice work Mark, looking great.
Thank you all for you kind comments. Gray, I don’t have good eyesight, they are called contact lenses and a very large magnifying glass. Without them I am the real Mr Magoo. Mark Regards Markwarren (Mark) Admin
 Looking fantastic Mark. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Many thanks Ian. Really enjoying this build. Mark Regards Markwarren (Mark) Admin
It looks like it and a joy to watch
Stunning work as always Mark, simply love what you're doing with this one..... Regards Alan
Many thanks Alan and Tom. A little more done this evening. I have some photos of the original prop, and the throttle sticks have some webbing on them as shown in the first picture. I had a hessian sample used for blinds that I thought would come in handy sometime, it’s amazing what I keep, so I used it to bind the shafts. The last pictures are them test fitted in place. Thanks for looking.
 looks amazing Mark. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
 Looking good as always Mark and great work Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Many thanks Ian, Andy for your comments. Mark Regards Markwarren (Mark) Admin
Looks great, totaly enjoying your build Jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Fantastic build Mark!  You have an excellent eye for detail. Great build! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,826 Points: 17,630 Location: ipswich
This is looking really great. Keep it coming.
Roy.
Love it Mark, excellent work.... Regards Alan
Many thanks for your comments and support everyone. A little more done over the last couple of days. I had been looking at the original prop pictures again and saw that the seat was completely different to the one supplied. So, armed with a cutting knife, sanders and some Milliput, I set to. The first couple of pictures show how it looks on the prop, whilst the remaining ones show my attempt of using the Milliput trying to get a cushion look. I also cut the original chair part down and again filled the holes with the putty. The final shots show it temporarily in place.
Thank you for looking.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
 Fantastic work Mark coming along Nicely. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Thank you for your support Ian. Just a quick update. I have now glued the internal cockpit panels and attached the control throttles. Then, I wired the cockpit lighting, using enamel coated copper wire. This wasn’t as easy as I first thought, as it was a very tight fit and I had to use some blue tack to hold it all in place before attaching the upper half to the base. I have also put a small blob of Bostic UV resin to hold the cable in place, under the seat area, to stop the cable from being pulled through and damaging the internal components. Once the two halves were attached, I then filled the seams with Vallejo putty. This will be left to dry hard before sanding down to a smooth finish.
More Soon Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
