launch planking Options
pfcdre
#1 Posted : 28 May 2018 12:16:38
hi everyone, would anyone know if there is an in depth tutorial on planking the launch, as this will be the first planking part of the model, in the instructions its clear about the first two planks on each side then its just photos of the completed hull, im looking for a fools guide i guess as from past experience i am completely useless. thanks
#2 Posted : 28 May 2018 21:00:47
Hi there, there isn't an in depth tutorial for planking the launch as such, other than that you see within the instructions. However, the instructions together with the official build diary will give you all the information you need to successfully plank the launch. Here is a link to the Official build area covering this task -
https://forum.model-spac....aspx?g=posts&t=729
Tips I will give you is first of all be very careful in handling the frames for the launch, they are pretty delicate and easily broken. Secondly, the strips used to plank the launch are very thin, this makes them malleable and easy to bend plus you may like to consider using superglue gel for attaching the strips, many have used this method.
Produce a build diary showing your progress and post often, this way we can follow your progress and hopefully prevent any serious errors creeping in. If you're unsure of anything then ask, there is a vast amount of information on the forum together with very experienced modellers who are only to willing to assist.
Lastly, here is a link that outlines the basics of planking model ships.
https://forum.model-spac...s&m=66855#post66855
You may find this interesting however, the instructions for the Victory are very precise and the best out there, taking you through the complete planking process step by step. Follow these and you should find you'll soon get into the swing of it.... In fact, it may just benefit you to start with planking the main ship first, get the hang of planking then move onto tackling the launch itself with a better understanding of what is required.
Hope this help and should you need any further info then just ask.....Cool Cool
pfcdre
#3 Posted : 29 May 2018 19:36:53
Thanks Alan, im gonna check those links out, i have subscribed to the 12 months build and i have an electric plank bender and every tool i could think of, various glues fillers etc so im good to go, i just really want this build to succeed i thrown everything at it lol.cheers
#4 Posted : 29 May 2018 23:30:34
Very pleased to hear you've subscribed to this one, you are going to have a great time putting her together.... Take your time and remember we're here to guide and assist if needed..... Good luck and I look forward to seeing you get started....Cool Cool
pfcdre
#5 Posted : 19 June 2018 23:00:25
Hi Alan i have successfully built the hull on the ships boat[launch] im really pleased with the result, thanks for the encouragement, im really happy at the moment with how its goingBigGrin
#6 Posted : 19 June 2018 23:18:53
Great to hear, just the main ship to do now….BigGrin BigGrin … How about posting up a couple of pics of your endeavours, always great to see members work....Cool Cool
pfcdre
#7 Posted : 20 June 2018 17:23:10
i only have a phone camera but when i work out how to post pics i will cheers
#8 Posted : 20 June 2018 21:38:03
Great choice of kit.
If you need help posting pics you can find a tutorial here -
http://forum.model-space....aspx?g=posts&t=244
This page was generated in 0.119 seconds.
