Die-cast trophy is bent Options
gingerale75
#1 Posted : 03 June 2018 19:06:24
Ahoy Shipmates,
I just completed issue 83 and checked the die-cast parts which will be painted and fitted in issue 90.
Unfortunately one of the spears is slightly bent on the trophy.
Could anyone suggest a method to bend it back? As the die-cast part is very brittle I don't want to "just" bend it and risk to snap.
Any suggestions? Or shall I ask Customer Service to send a replacement part?
Thanks.
gingerale75 attached the following image(s):
Happy building!
Laszlo
Finished builds: HMS Victory, HMS Victory Cross-Section
#2 Posted : 03 June 2018 21:48:18
gingerale75 wrote:
Ahoy Shipmates,
Thanks.
Safest way would be to ask Customer Service to send a replacement part. Whilst you await its arrival you could always try to straighten it by bending it after some gentle heat application.
This page was generated in 0.040 seconds.
