 Brilliant start jase Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
 Lovely start Jase. Mark Regards Markwarren (Mark) Admin
Great start Jase, nice work.
Joined: 26/05/2015 Posts: 121 Points: 366 Location: Wexford, Ireland
Great Start!  Love your detailed updates Jase! Best of luck with your build! Regards, Arek
Good to see another entry underway
Looking great Jase, will be watching..... Regards Alan
Great start Jase! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Thanks all for the comments of support
Cannon
I have used milliput to fill the original hole as well as my new eye hook holes. I have decided to change the eyebolts I am using and the new ones are smaller, there is a tiny hole in the milliput for these. its left overnight to Harden.
Display base
I have cut out a small section of deck to add some grating interest. The bulwarks have been painted read. I have done my best to match the bright red of Endeavour The grating frame has been assembled the grating is just dry fitted at the moment
Jasejase attached the following image(s): “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
the grating edge was painted black before being glued into place. the grating give a wash in watered down wood glue and then sanded down
cannon parts were test fitted prior to painting fit is all good.
while paint is drying the cap rail was cut to length and painted black
the cannon carriage is now assembled with black bolt heads painted onto the carriage frame and trucks and the ends the two brass bar spacers are also painted black.
cannon is just test fitted at the moment
 Looking good jase very nicely done Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Coming on great Jase, Mark Regards Markwarren (Mark) Admin
Thanks both, a bit of rigging next I think “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Coming along nicely, looking good.
Coming along really nicely!  Really like the grating also how they compose with step on the gunwale in opposite corner. Regards, Arek
Thanks both for the kind comments Jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
A bit more progress
the eye hooks have been installed for the rigging
The Axel block and tackle has been installed, I am not displaying my cannon run out, all will become clear soon.
The carriage was then rigged up, the cannon will be added after for ease of access when rigging up the blocks
A ripple block has been added to the deck, again all will become clear soon
some more work has been done on the capping rail.
Nice update Jase, look good. Mark Regards Markwarren (Mark) Admin
Looking great Jase, nice work.
Thanks Both for looking in and taking time to leave a comment Jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
