Jaguar E-Type Official Build Diary - issues 66 - 70 Options
#1 Posted : 03 June 2018 22:39:51
Issue 66
Contents: Rear floor, Screws.
Turning the cockpit assembly from Stage 62 over, line up the rear floor with the step behind the seats.Ensuring the three holes in the rear floor fit over the holes
at the back of the cockpit, join the parts together with three screws.
This issue is now complete. Store the assembly and any unused parts in an issue labelled bag.
#2 Posted : 03 June 2018 22:41:49
Issue 67
Contents: Spare wheel cover, Pull.
Line up the D-shaped lug on the back of the pull with the matching hole in the spare wheel cover and press the pull firmly into place. Retrieving the cockpit assembly from Stage 66, lay the spare wheel cover in the recess in the rear floor.
#3 Posted : 06 June 2018 11:50:58
Issue 68
Contents: Fuel tank base,Fuel tank top,Fuel pump,Filler pipe,Fuel tank sender,Screw
Fit the pin on the sender into the hole in the top of the tank as shown, and press it into place.Line up the three pins on the back of the fuel pump with the matching holes in the tank, and having pressed it into place secure it with a screw.Fit the D-shaped hole on the filler over the matching lug on the tank, and fix it in place with a screw. The two halves will not be fixed permanently until a later stage but.you can test-fit the top of the fuel tank to the base by bringing the two halves together.
#4 Posted : 10 June 2018 22:55:54
Issue 69
Contents: Long rubbing strips type A (x 2), Long rubbing strip type B, Long rubbing strips type C (x 2), Short rubbing strips type A (x 3), Short rubbing strips type B (x 3), Short rubbing strips type C (x 2), Hinged extension panel
Take the assembly from Stage 67 and all the parts provided this time.Lay out the hinged panel and all five short rubbing strips in order as shown.Taking one of the short rubbing strips type B, press the two lugs into the end holes on the hinged panel,fit the other two matching strips into the other end of the hinged panel and into the centre holes.Fit the first of the short rubbing strips type C, noting which way up it goes: the longer tail is at the bottom.Fit the second short rubbing strip type C to complete the hinged panel.
Lay out the spare wheel cover and the long rubbing strips type A and B.Fit the long rubbing strip type A to the edge of the spare wheel cover, fitting a long rubbing strip type B in the centre holes followed by the remaining long rubbing strip A to complete the spare wheel cover.
Lay out the long rubbing strips type C and the short strips type A next to the floor of the luggage compartment.Fit a short rubbing strip type A in front of the spare wheel compartment with the pointed end to the front, followed by the remaining two type A strips in the same way.Fit a long rubbing strip type C alongside the spare wheel compartment, followed by the remaining strip C.Place the spare wheel cover in the recess in the floor and lay the extension panel
down at the front of the luggage compartment.
#5 Posted : 10 June 2018 22:59:16
Issue 70
Contents: Right rear wheel arch (inner),Screws.
Taking the assembly from stage 69,fit the notches in the edge of the wheel arch over the three tabs projecting from the side of the rear floor. Holding the part in place, secure it by driving screws through the three tabs.
This page was generated in 0.180 seconds.
