Well, I'm full swing in work at the moment but hoping to get started this weekend. My pack has arrived though! Do not expect too much.....I am a beginner! Cook 250 - Endeavour cannon biuld competition entry Rabbit6 attached the following image(s):
Good to see you up for this one. Novice or not, with a little imagination you`ll be suprised what you can do. Give it a go. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Just give it your best. You may suprise yourself. It`s all a learning curve, I have a few ships in progress but not one finished as yet so I`m no expert. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Joined: 26/05/2015 Posts: 121 Points: 366 Location: Wexford, Ireland
Best of luck with your build!  Regards, Arek
Always good to see another entry and good luck with your build.... Beginner or not, we all started the same way and am sure you'll do a great job, having fun along the way.... Will be watching..... Regards Alan
Good luck with your build, dont be concerned with the level of your experience none of us have any idea how this will be judged Looking forward to seeing your build Jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Good luck with your own rendition and try not to be phased too much by the mega builds as all entrants have equal chance as the competition is not about the most lavish build.
 Best of luck with your build Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Good luck with the build I'm sure you will do well, if nothing else it's all experience. Ken's the name modeling's the game.
Good luck with your build. Not long left now. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Now, some of you may be asking what I've been doing in terms of my build, well, in between work I managed to split part of one of the axles when separating it from the wood, and had to try several different methods to get the two halves attached back together again! My build is now on its way although I realise I have very little time left. Still, I like a challenge. Rabbit6 attached the following image(s):
Good to see it’s underway
Good to see you up and running. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Great to see you up and running on this one, hope you manage to finish it before the deadline..... All looking good.... Regards Alan
Sounds like you are up for the challenge. I look forward to seeing some more soon. Mark Regards Markwarren (Mark) Admin
 Nice start and good luck Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
