80 Pages 123>»
Sticky Wickett
#1 Posted : 07 June 2018 07:46:36
Good morning from 'The Dockyard'.
I've been experiencing issues loading my original build diary, so to mitigate any future problems I have decided to start a new thread continuing my 1/48 scale U230 U-boat project. Here's the link to the original diary from which this continues: 1/48 scale U-Boat U230 [Part 1]
Currently i'm in the process of modifying the conning tower to resemble the type 4 version as found on U230 from 1942 onwards.
Not too much modelling has been done this week, but plenty of head scratching, pondering, measuring, staring into space as I try to figure out how to make the complex set of tapered curves found on the type 4 tower.
Using a 1/72 donor model for guidance I have already made the 'footprint' for the tower and this week I began to make the lower platform, using the same technique as before; measuring the donor model and multiplying the measurements by a factor of 1.5 to correctly scale up from 1/72 scale to 1/48 scale.
The attached photo shows the donor model lower platform, a drawing of it with dimensions and the scaled up version, all drawn out onto 0.5mm thick plastic sheet.
Sticky Wickett
#2 Posted : 07 June 2018 07:48:18
The new lower platform profile cut out.
Sticky Wickett
#3 Posted : 07 June 2018 07:49:55
I then glued a thin strip of plastic around its edge. This acts as a locator for the tapered sides and allows the mahogany decking to butt up against it.
Sticky Wickett
#4 Posted : 07 June 2018 07:51:38
The attached photo shows the strip glued in place. I have left it oversize for this picture so that you can better see it. It was then cut to length.
Sticky Wickett
#5 Posted : 07 June 2018 07:52:24
The lower platform being offered up to the existing conning tower.
Sticky Wickett
#6 Posted : 07 June 2018 07:53:18
My 1/48 scale conning tower and the 1/72 scale donor version side by side.
Sticky Wickett
#7 Posted : 07 June 2018 07:54:55
A photo of the 1/72 donor conning tower showing the extended port side.
Sticky Wickett
#8 Posted : 07 June 2018 07:56:18
Both versions side by side. As you see there is a lot more work to be done to convert my 1/48 scale version to build it up to resemble the 1/72 donor model next to it.
Sticky Wickett
#9 Posted : 07 June 2018 07:57:37
Well that concludes this weeks update. More to follow next week.
Thanks for looking in, have a great weekend and happy modelling.
Phil W.BigGrin
#10 Posted : 07 June 2018 08:59:48
Very nice update, progressing very nicely....Drool Drool
#11 Posted : 07 June 2018 11:19:04
Great update and nice work. I can see you have a lot of scratch building to do to get the correct profile.
Sticky Wickett
#12 Posted : 07 June 2018 11:47:26
Thank you Alan! Much appreciated.Cool
Phil W.
Sticky Wickett
#13 Posted : 07 June 2018 11:48:36
Thanks for looking in Graeme.Cool Yes, lots of scratch building and lots of head scratching as I try and work out how to do it all!LOL
Phil W.
#14 Posted : 07 June 2018 12:45:24
BigGrin Looking really good Phil.BigGrin Drool
Sticky Wickett
#15 Posted : 07 June 2018 13:19:27
Thank you very much Ian!Cool
Phil W.
#16 Posted : 07 June 2018 20:07:59
Very nice work Phil. I usually take an evening when planning a part of the model, and yes a lot of the time is looking into thin air.LOL
Sticky Wickett
#17 Posted : 08 June 2018 18:19:49
Absolutely Mark. Staring out of the window or looking at the carpet!LOL
Phil W.
#18 Posted : 18 July 2018 12:04:30
Wow great work PhilBigGrin really outstanding scratch building on the conningtower bandstand Drool regards PhilCool
Sticky Wickett
#19 Posted : 20 July 2018 13:19:35
Thanks very much Phil!BigGrin Haven't posted any updates for a few weeks now due to the fact my flat has been like an oven in the evenings. Great weather, but not conducive to model making I've found, especially after a days work. This week has seen me continue with a bit more research on the conning tower and I should be posting an update next Thursday.
Phil.
Sticky Wickett
#20 Posted : 16 August 2018 20:56:42
Good evening from 'The Dockyard'!
Well, it's been a while since my last post and i'll be totally honest, my flat has been like an oven during the hot spell and consequently I found it difficult to get into a model making frame of mind when I was sweating cobs! LOL
This weeks post covers the sporadic modelling I did do, much of it taking place over the last three weeks. Prior to that i spent many hours looking at photos of the real U230 and comparing them to the 1/72 scale donor model and my 1/48 scale version. Not all plain sailing [pardon the pun] as dimensions converted from 1/72 to 1/48 looked out of place and both versions neither looked like the only photo I have of the real U230's conning tower. This then provoked lots of time staring at the floor or out of the window as I tried to figure out a solution, double checking and triple checking everything as I went. These scenarios can't really be represented by photos, so the images you see here were borne from many hours of pondering. I wanted to get this stage of my build right from the start as any discrepancies would prove to be difficult to correct later down the line.Blink Blushing
So, hello all and it's nice to be back!BigGrin
The attached photo shows the location of the lower deck being marked out on the conning tower with a pencil clipped to an engineers square; just getting to this point where I was confident of the correct height can be summed up in a few words on here but involved lots of cross-checking and head scratching.
80 Pages 123>»
This page was generated in 0.340 seconds.
