2 Pages 12>
Magpie1832's Cook 250 Options
#1 Posted : 22 May 2018 00:07:27
Cook 250 - Endeavour cannon build competition entry
Hi Guys, I've never enter one of these competitions so thought Why not!.... It's not going to super special but will do the best I can with the time I have to do it.
Parts received and sat awaiting the 1st June.
All the best to the other entries...ThumpUp
Chris Cool Cool Cool
#2 Posted : 22 May 2018 00:11:37
Good luck with the comp Chris and of course hope your build goes to plan... look forward to seeing how you progress.....Cool Cool
#3 Posted : 22 May 2018 00:16:39
Good luck Chris BigGrin
#4 Posted : 22 May 2018 05:12:50
Good luck Cool
Sticky Wickett
#5 Posted : 24 May 2018 09:17:37
Good luck in the Cook 250 comp Chris!
Phil W.
#6 Posted : 03 June 2018 19:26:51
Hi Guys,
Made a start today.
Firstly I cleaned up all the parts. Then took to re-shaping the cannon barrel.
I then built up the carriage and gave it a coat or red ochre. I installed the wheels and drilled out the shafts for the pins. Mean while I had the barrel in Blackener. Once done I glued Tin foil to the rear.
I will post more this week.
Cheers
Chris
magpie1832 attached the following image(s):
#7 Posted : 03 June 2018 19:41:57
Looking great Chris
#8 Posted : 03 June 2018 19:58:24
BigGrin Great start Chris Cool
Martyn
#9 Posted : 03 June 2018 21:18:30
Nice start
arek
#10 Posted : 04 June 2018 00:34:17
Nice start Chris! ThumpUp
Tin foil??Blink interesting...
Arek
#11 Posted : 04 June 2018 07:12:30
Nice start, good luck with the entryCool
#12 Posted : 04 June 2018 07:26:39
Nice start Chris.Cool BigGrin
Sticky Wickett
#13 Posted : 04 June 2018 12:41:28
Looking the part Chris.
Phil W.
#14 Posted : 06 June 2018 23:37:41
Thanks for the nice comments guys.
I haven't decided where I'm going with this one but am copying a picture of one so may just recreate that picture. Hopefully!
Here are the latest pics. I've moved the metal stays to where they should be, also added the wheel pins now the brass is black. I added the cannon barrel tied down rigging.
Chris
#15 Posted : 07 June 2018 08:38:39
Looking sweet Chris, lovely work....Drool Drool .. Good luck with your entry....
kpnuts
#16 Posted : 12 June 2018 17:16:40
Liking that a lot.
#17 Posted : 12 June 2018 19:49:21
Looks great I like the rain cover
arek
#18 Posted : 12 June 2018 20:00:08
Great attention to details!
Arek
#19 Posted : 17 June 2018 18:23:19
Thanks for the comments guys, much appreciated.
I have started on the base, which is set to a specific size. I will reveal later why but its not what you would expect. Flapper
Here are the latest pics, as mentioned i did the base also i have installed the caps and pins on the cannon barrel.
Chris
#20 Posted : 17 June 2018 18:36:18
Confused Mmm intriguing about the size of the base Confused Really looking forward to the next update Cool . Lovely job Chris Cool
Martyn
2 Pages 12>
