No-Sand Filler for plastic models Options
CaptnBirdseye
#1 Posted : 07 June 2018 13:47:15
Rank: Superelite
This is a water-based putty, that doesn't require sanding. It leaves detail intact.
'Waterfiller Putty is a new formula of waterbased resin, to fill those gaps we find building our plastic models. It’s a white colored dense fluid, with some properties which turns the annoying putty-and-sanding into a fast and straightforward job.
Firstly, know that in most situations you need no sanding at all.
From now on you will not need to re-carve all the little details you always lose in other-brands-putty session.'
Thinning with water. Removing with alcohol or sopropyl alcohol / Isopropanol (IPA).
http://www.true-earth.co...Stucco_Waterfiller.html
I hope you find this useful
Gray
#2 Posted : 07 June 2018 15:52:14
Looks interesting and better still if it does the trick Cool
#3 Posted : 07 June 2018 18:00:30
Looks good. Cool
5 euros not a bad price, but over double that (11 Euros) for the cheapest postage. Blink
Had a quick look for a Uk supplier to compare but can`t find one.Confused
This page was generated in 0.133 seconds.
