hair line gaps in bow when replacing plank Options
ronald305
#1 Posted : 17 June 2018 23:00:58
Hi there
I know it's been awhile since I posted any questions here for help anyway first
my problem was I had to remove the second plank on one side of the bow it was not curving right but when I was gertting ready to add a new piece of planking
in it's spot I notice there wil be fine thin gaps between the planks when all the other planking's are closed in what should I do is it ok to fill in the gaps with putty or find a piece of planking wide enough to fit in place, I will be painting the model the offical colors thank you
Ronald
#2 Posted : 17 June 2018 23:06:55
Hi Ronald, you say they are hair line gaps so sounds like they are very small. As you have decided to paint your model then it would be fine to use a general wood filler to fill the gaps, sand it all smooth. Once painted it should be hidden....Cool Cool
ronald305
#3 Posted : 18 June 2018 00:34:29
ok thanks Alan
Ronald
This page was generated in 2.127 seconds.
