Weathering the decks Options
6649mgk
#1 Posted : 20 June 2018 16:28:38
Rank: Amateur Level 1
Hi all , I am now up to Issue 46 and have planked of the upper gun deck. Has anyone out there used a coloured varnish or other wood stain to provide an authentic look and one I can use on all decks? I feel hat just using a clear matt varnish on the wood provided would not leave the look I want. Any suggestions greatly received. Thanks,
#2 Posted : 20 June 2018 18:41:22
Hi Mark!
If its a weathered look your after, have a look at Post 51 on Page 3 of my Messines WW1 diorama where I made up a weathering solution for wood using white vinegar and steel wool. Its basically the same as the 'Weather it' product but far cheaper to make your own.
Once the wood is the colour you want then let it dry out and clear matt varnish the decks (or your Victory will smell like a fish and chip shop!)
Failing that use a water or spirit based wood stain and dilute it right down so it just 'tints' the wood a coat at a time.
Hope that helps.
Robin.
6649mgk
#3 Posted : 20 June 2018 19:24:22
Thanks, Robin. I'll take a look. Regards, Mark
#4 Posted : 20 June 2018 23:36:59
Hi Mark,
The colour, shading and weathering of decking is really down to personal preference and the forum has numerous posts on what other modellers have done and their results. Personally, I tend to like the look of Danish Oil, the application of each coat darkens the strips and protects the wood at the same time. For me, two coats of Danish Oil is normally sufficient. Wood stains are good, with a wide variety of shades and colours to choose from. Take a trip to your nearest DIY store, you'll be surprised by the variety on offer.
My biggest piece of advice before working on the model itself would be to try doing some test strips using differing stains, washes etc. This will give you a good idea on application and how it is likely to look, from there you can make your decision as to the best way forward for your model.
One note of caution, the using of wood stains and washes can be difficult to control, they can very easily spread out to areas you don't want them to go.
A look through some of the topics here should prove to be very helpful for you also:
https://forum.model-spac...aspx?g=topics&f=102
This page was generated in 0.039 seconds.
