3 Pages <123>
Robin's Waterlogged Cook 250 Cannon Build Options
#21 Posted : 10 June 2018 20:53:24
Many thanks to Martyn, Jase, Paul, Chris, Arek, Mr T., Alan, Mark, Phil and Derek for their kind words!Blushing Further blushes from the fact I never thought of fish and aquarium shops! Good thinking there Derek!Cool The sharks I've got will be representing two of the Reef Shark species, probably the Grey and White Tipped although a degree of artistic licence is required as this pair are about twice the size of the 'proper' sharks (and one of them is a Great White by the shape of it!)Blink Still, they were the only 'small' sharks I could find at the Aquarium. We saw dozens of the real things back in '88 when we went on holiday to Cairns - all being hand fed by the pontoon divers (made me glad I couldn't swim!)BigGrin
Ok then, in the absence of real coral, here's the cheapie alternative!
This time around I decided to try wood staining the MDF base before varnishing it, the smaller one used in the Chindit build is only the basis for the resin mould so it didn’t need any ‘fancifying’. Photo 1 shows the plain MDF after a single coat of spirit based Rustins Teak woodstain – the top flat surface went on quite well but the shaped sides … its amazing how much that stuff soaks the stain up, each brush-full lasted for about an inch of moulding! Photo 2 illustrates the situation after two full coats, slightly darker but the sides are still like a sponge! Before beginning the varnishing I cut a piece of 2mm plasticard (my decades old stuff) to form a base plate onto which the Thermalite block will be glued once its been bashed about and cut to size as seen in Photo 3. The block in question is shown in Photo 4, this is how I found it in the garden – fairly clean considering how long it’s been out there. As you can see, it’s already had a chunk cut off it (to fill in a gap in a wall somewhere). This material is essentially a cement ‘aero bar’, it can be cut easily with a standard thin saw but try to shape it the traditional way (chiselling a groove all around and then hitting it with something heavy) results in the very rough uneven surface shown at the top. This of course is excellent to fashion a ‘coral reef’!Cool
The first job was to take my little jeweller’s hammer and an old, flat bladed screwdriver and begin to chisel away some of the block to form the edge of the reef. After about ten minutes the jeweller’s hammer was replaced with something much bigger! The first attempt is shown in Photo 5. At this point I then placed the plasticard base plate template on top of the block and carefully sawed along the two ends giving me the actual length of block required. This is shown in Photo 6 with the two yellow arrows indicating the cuts made along the ends of the base plate. Once I had the length sorted out I also increased the banging away (scientifically produced excavations) to remove more of the deeper sections leading up to the reef itself. Once that looked sort of ok (alterations will no doubt follow later) I replaced the plasticard template to saw in the lengthwise cut. This is shown still under way in Photo 7 - it’s a little harder to see clearly as the block is resting on its side in this shot. Most of the side waste has gone with a little still to come away on the right. In Photo 8 we have the remainder of the block, as you can see, I’ve got a little ‘Emergency Back Up Reef’ left on there just in case! And finally, the finished Thermalite ‘reef’ is shown glued onto the plasticard base in Photo 9. This is only the reef part however, I will be building up the sandbank element soon using some of the Woodland Scenics Subterrain Foam Putty, this will ‘feather in’ the part of the terrain closest to the camera, and with the top covering of actual beach sand will allow me to partly bury some of the jetsam thrown overboard from Endeavour. The vertical sides of the reef will be enclosed in a thin wooden shaped surround, stained and varnished to match the base, more on that bit later.
In the next instalment – I’d better get started on that bloomin’ cannon!
Until then Happy Modelling to all the other entrants!
Robin.
#22 Posted : 10 June 2018 21:04:17
Nice work Robin, great idea for the reef.
#23 Posted : 10 June 2018 21:22:17
BigGrin Brilliant start Robin. Corel sand comes in three different sizes fine medium and corse . I think fine and medium will probably be the right size Cool
Martyn
#24 Posted : 17 June 2018 21:16:18
Many thanks again to Graeme and Martyn! I wish I'd thought of the aquarium sand in time but never mind - instead of the white Queensland beaches we'll be having the golden sands of Devon's Bigbury beach! (I've actually got a big bag of aquarium sand which I bought for our fish pond but the real beach sand has tiny bits of shell in it which looks really nice - and judging by the colour of the aquarium sand it probably came from Bigbury anyway!!)BigGrin
Ok then, everybody must be getting to know this bit by heart but here it is again! Whoever it was commented that this cannon was a fiddly little blighter – they weren’t kidding! It’s a long time since I’ve been down this small in wood rather than plastic and resin and it showed!
Photo 1 illustrates the basic kit parts, all the same parts but with a couple of slight differences which I’ll come to later. Like most others, I gave the carriage parts a good sanding along the flat sides whilst the parts were still in the fret before carefully (very carefully – there’s nothing like only having one piece of everything with no spares to concentrate the mind), cutting out the sides and axles and sanding back the locating ‘bumps’ as shown in Photo 2. The various locations for the ring bolts were marked on the first side piece and drilled out, then that one was placed over the second side piece and used as a template to start the holes in that one. This was not as easy as it sounds however – fiddly doesn’t come close!Cursing The axles were glued to the carriage sides before I filed down the square ends into rounds as in Photo 3. I first glued the pieces with the Deluxe Card Glue I used on last year’s paper Pups and then applied runny super glue to the joints after the first glue had dried. Photo 4 shows the wheels or ‘Trucks’ as they were properly called under construction. This was the first deviation from the parts mentioned in the instructions – instead of larger wheels at the front, all four of mine were the same size! Still, in this scale it hardly matters. The first two wheels were cut out and sanded down by hand. I had an idea to try and find a long nut and bolt small enough to thread the wheel on to use the rotary tool as a kind of hand held ‘lathe’ but the set of spectacle bits I’ve got didn’t have anything long enough for the job. However, in Photo 5 I’ve illustrated the simpler method I came up with – instead of a bolt and nut, I simply pushed the wheel over a sharp conical diamond dust grinding tool, shown at the top right. The friction alone was sufficient to keep the wheel in place with the rotary running and I then just ran the wheel along the lollypop stick sandpaper gizmo sanding down the little stubs until the wheel was perfectly round as shown here. The four wheels are sanded and glued to the carriage in Photo 6. Now for the paint scheme. My cannon is based on photos of the recovered original cannon from the Endeavour in the James Cook Museum in Cooktown, Australia. This particular exhibit is painted in a deep red, almost maroon colour so that’s what I’ve tried for here. As far as I know, no trace of the carriages were found when the guns were recovered so the actual ‘redness’ is probably lost to history, (the sister cannon at the National Maritime Museum in London appears to be on an unpainted bare wood carriage). Photo 7 shows the initial paint test on a piece of the wheels fret using Vallejo 70.926 Red. This is quite a good match on its own so I began with the first coat gripping the carriage by its rear axle in a pair of sprung tweezers as shown in Photo 8. After a second coat and a subsequent re-drilling of the holes the carriage looked as in Photo 9. The next task was to take my decades old pot of Citadel Skaven Brown Ink and apply it neat along the vertical joints on the carriage tops (the steps) to add depth and shadows and then a diluted wash over the rest of the woodwork as shown in Photo 10. Once that had dried I then made a mix of mostly Revell Matt White acrylic with a touch of the Vallejo Red and dry brushed over the edges of the carriage to bring out the highlights as finally seen in Photo 11.
I still have the carriage stool bed and the elevation quoin to make and paint – they’ll be coming in the next instalment with the ‘metal work’!
Back soon!
Robin.
#25 Posted : 17 June 2018 21:41:01
Some very nice work Robin, coming on excellent.Love
#26 Posted : 17 June 2018 21:47:45
BigGrin brilliant work Robin loving it Cool
Martyn
#27 Posted : 20 June 2018 21:03:11
Thanks again to Mark and Martyn! At last you can see the finished cannon! (Took me longer than I thought it would!)
This is the point where I came to the second ‘deviation’ from the cannon instructions. As you all know we get two brass rods with the kit; a 1mm one for the bed bolt through the wooden carriage and a 1.5mm biggie for the cannon barrel trunions. The 1mm rod fitted the hole drilled in the brass barrel perfectly – which of course meant that the 1.5mm one didn’t! So, as shown in Photo 12, the first task was to drill through the barrel with a trio of ever increasing width drill bits to get the hole widened out for the trunion bar. With that done, the brass and copper components were given a nice long bath in white vinegar to remove any traces of grease and oil (especially from that cannon), occasionally ‘swishing’ them around with a fairly soft paintbrush to clean off any deposits, this was done in one of my unused larger resin mixing cups as illustrated in Photo 13. After the cleaning the parts were then rinsed off in a clean water bath and dried between tissue paper (toilet rolls!)Blushing Then they went into another bath this time of ‘Blacken-it’ chemical blackener. After about twenty minutes or so the parts looked as they appear in Photo 14 – all nice and uniform black (for now)Blink . What I forgot to show before that was the ring bolts for the carriage sides, as shown in Photo 15, these were made from 0.5mm copper wire which was wound around a suitable drill bit held in the mini vice forming a coil of three or four rings. After removal from the drill bit former the coil was cut into individual rings two of which were threaded onto the copper ring bolts and carefully squeezed closed as shown here. Before carrying on with the metal parts I decided to add on the tiny bolt heads around the wooden trucks or wheels. Although they should really be the same ‘black iron’ as the rest of the metal parts, I decided to use my old pot of Citadel Bolt Gun Metal as shown in Photo 16. As you can see from that photo, the paint has long since passed its sell by date (must be 20+ years old by now) and is thick and gloopy to say the least! This though makes it perfect for applying with the tip of a large sewing needle to create raised dots of paint to simulate the iron bolts. The first two wheels are shown ‘bolted’ in Photo 17. It is important to clean off the needle after every few dots to prevent too much build up of paint on the tip, which will eventually prevent the application of small deposits. In actual fact I’d just finished the third wheel when I thought “I must mention cleaning the tip in the diary” as I began the last wheel without cleaning the tip and instead of a bolt I ended up with something like a hub cap! That required a quick clean off and a red re-paint for the wheel before I could finish it off! Notice the colour of the barrel here, after twenty-four hours the black finish had converted itself into an antique bronze (which I actually quite liked). Photo 18, which shows the other side of the carriage was taken earlier when the barrel was still the intended black. Instead of using the metal pins on the trunnion brackets I decided to try and model the mechanism which allows the brackets to be opened up allowing the cannon to be removed. I did wonder at one point if it was only the cannon barrels which were thrown overboard (which would have meant a lot less building)BigGrin but one of the eyewitness accounts did say the carriages went too! The arrow points to the rear hole in the bracket which is where the hinge mechanism was fitted. The hinge is essentially a curved metal loop which the bracket swings back over after being released at the front end. Photos 19 to 22 show the initial trial loop under construction. First a selection of three drill bits were used to drill out a hole in a section of Plastruct 0.8 x 2.5mm Styrene Strip. I tried to get the hole slightly closer to one side than the other. Next the strip was razor trimmed back to just above the hole with the corners sliced off before then sanding the edges to a rounded profile. Finally the resulting loop was sliced off to create the piece seen placed on the trunnion bracket. The thinner end made by the off centre hole drilling now drops down into the brass trunnion bracket pin hole as shown here. That worked great for the prototype but wasn’t very easy to paint so I came up with the version shown in Photo 23. I now realise of course I could have simply spray painted the darned things before slicing off the loop – dead line panic setting in! Anyhow, it was easier spraying the new version with a can of Poundland Matt Black Primer as shown in Photo 24, before then rubbing over the black with a dash of Uschi Steel Type Metal Polishing Powder as in Photo 25. The locking mechanism up the front end is equally as simple – just an iron pin which sticks up through the bracket with a horizontal hole drilled through into which is pushed an iron rod or bolt to lock the bracket down. The bolt is secured to the carriage by a short chain to prevent it being ‘mislaid’. The iron pin was made from a length of Plastruct 1mm Styrene Round Rod with a tiny hole drilled through it. With the hole in place I could then sand the rod down until the diameter matched the size of the hole in the brass bracket. Sanding the rod to size first would have made it almost impossible to drill it afterwards. A single strand of 0.2mm electrical wire was then bent double and twisted up using pliers and a pin vice to represent the chain. One of the strands was snipped away leaving the other to be inserted through the hole, super gluing it in position as shown in Photo 26. The two pins are shown semi completed in Photo 27, the one on the left is done with the ‘chain’ bent around and snipped off and the top of the rod cut back, the right hand one has still to be trimmed. These were also sprayed matt black and steel powder dusted before cutting down to size as shown in Photo 28. Once completed, the hinges and locks were super glued into position as shown in Photo 29. The hinges were glued to the carriage and the bracket hole, the locks just to the bracket hole – the chain ends are just kept there by the tension of the wire, no glue required. And finally, the entire cannon in all its miniscule glory is shown in Photo 30. The quoin I left in natural wood with the tip of a cocktail stick inserted into a tiny, drilled hole for its handle. The barrel has gone right back to its bronze effect again despite me having gone over it with a wire brush in the rotary tool and re-blackening it all over again. Ah well, it IS under water after all (and its even getting the first signs of coral growth as well) so I’m happy with that!Cool
Well I finally got the actual subject of the diorama completed – so much for ‘I can build that little thing in a couple of evenings!’ It was good fun going back to wood again though – now onto the base work again!
‘Till later.
Robin.
#28 Posted : 20 June 2018 21:27:41
Great job Robin, it looks fantastic.
#29 Posted : 20 June 2018 21:46:43
Love the colour
S they look like they are being seen through the filter of the ocean, great work
#30 Posted : 20 June 2018 21:46:55
BigGrin brilliant job Robin looking forward to the next update Cool
Martyn
#31 Posted : 21 June 2018 10:30:51
Fab work and attention to detail, though are you leaving the quoin in place as its unlikely to have been in situ when the guns were dumped overboard., likely the quoins were displaced as the guns went overboard/sank.
#32 Posted : 21 June 2018 11:50:04
Love Lovely work Robin, looking forward to the next instalment.Love
#33 Posted : 22 June 2018 21:32:05
Very nice robin. I tried to add that level of detail but my eyes wouldn't help lol.
Chris
kpnuts
#34 Posted : 23 June 2018 14:17:39
Amazing work mate
#35 Posted : 24 June 2018 08:58:37
Excellent work, looks fab....Cool Cool
#36 Posted : 27 June 2018 16:49:18
Grateful thanks to Graeme, Jase, Martyn, Mr T, Mark, Chris, Ken and Alan for their kind words as always!Blushing Blushing
With regards to the quoin, I did think about that and did a first placement test without it - whether its just something pyschological (or all the other cannon I've made on other ships) I don't know but it just didn't look right without it. Unfortunately by the time I changed my mind again and decided not to have it in place, the tiny drop of Gorilla Wood Glue had done its job so well I can't shift the little blighter without risking the entire carriage! OK then, the canon hit the reef muzzle first and jammed the ruddy quoin in solid!Blink Blushing
That darned clock's ticking again!BigGrin
The first task in continuing the Thermalite block reef was to seal the surfaces with a couple of thick coats of acrylic white poster paint. Because of the material itself (cement and air) once the surface is broken it remains very dusty and a little unstable, refusing to accept any glues or other materials (except the paint of course). I was going to use some of my stored white masonry paint – unfortunately, I stored it somewhere very safe and long since forgotten! At this stage the Thermalite has already been glued onto a base of plasticard as you can see in the corner in Photo 10. With the block now sealed, I could then construct an enclosing wooden surround to tidy up the rough edges of the block. This was made out of thin Beechwood, shaped with my rotary tool set mini jigsaw, allowing a raised bit down the sandy end and chamfered at 45 degrees at the corners. The four sides were then ‘Gorilla Wood Glued’ as shown in Photo 11. Once set, the surround was given a coat of Rustin’s Wood Dye (in teak) and then glued onto the sides of the block with the Gorilla Wood Glue again. I had intended to varnish the surround to match the gloss of the MDF plinth but that wood dye brought out such a beautiful wood grain I’ve decided to leave it matt and unvarnished as seen in Photo 12. The next step was to create the sandy area running up to the coral down the ‘deep end’ by filling up the ‘empty’ part with Woodland Scenics Terrain Foam Putty – this is the soft ‘squidgy’ material that dries into a form of polystyrene, which I last used on the Messines diorama. It was pressed into position and moulded with just fingers and a little water to create the gently sloping sea bed illustrated in Photo 13. When everything was dry it was time to add some colour! For the most part I used an airbrush to spray on thin coats of acrylic – the sandy area was covered with Vallejo Tan Yellow 70.912 and this colour was also lightly sprayed over the coral rocks as well. I then added some Vallejo Sky Grey 70.989 to the sand paint to grey it down a little and airbrushed that over the coral before adding a little Black acrylic (my first ever purchase of Mig paint now stocked in the local Antics) and airbrushed in the shadows to the deeper crevices and the little ‘caves’ as well as the leading edge of the coral reef itself. Finally I added some Revell Matt White acrylic to the Sand and drybrushed over the coral to bring out the highlights on the edges, gradually adding more and more white until the final highlighting was pure white. The final effect is shown in Photo 14 but this is just the ‘foundation’ colour. The painted sand will be covered next with real beach sand and much of the coral with be equipped with brightly coloured bits and pieces to represent the living coral and sea plants etc.
More on that soon!
Robin.
kpnuts
#37 Posted : 27 June 2018 17:34:49
That is looking very good
#38 Posted : 27 June 2018 18:24:51
Lovely display base Cool
#39 Posted : 27 June 2018 21:43:11
Looking really excellent. Great work.Love
#40 Posted : 28 June 2018 21:46:20
Thanks again to Ken, Mr T and Mark! Where IS that ticking coming from!BigGrin
Here’s the first in a series of ‘quickies’, I’m actually much further on than the pics suggest (thank goodness!) but I need to put what I’ve done down for the diary before the clock stops ticking! Mr Mandibles the shark is finished (and looking pretty good too) and nearly ready to go in position but first I have to complete my resin barrels (you’ll see why later). But first, the first addition to the base was this, the Amati Anchor kit as shown in Photo 1. This is Kit No. 4010/40, the 40mm sized ‘Old Style Anchor’. Including this in my diorama is another piece of artistic licence I’m afraid. When reading the accounts of the grounding I first thought that they’d ditched one of the two main or ‘Bower’ anchors as part of the emergency lightening of the ship. It turns out however that the anchor was actually lost after the crew secured the anchor between the ship’s boats and rowed it out into deep water before dropping it to the seabed in an attempt to winch the Endeavour back off the reef. Whether the attempt was successful or the ship just floated free on the next high tide anyway I don’t know, but whichever, the anchor lodged tight on the seabed and the rope cable snapped whilst trying to retrieve it – in other words, the anchor wouldn’t be found anywhere near the cannons and stores dumped overboard!Blushing Anyhow, this is the basic kit with the metal anchor glued into the wooden stock. I had to sand down the stock a fair bit in order to allow the brass squares to fit far enough in towards the shaft. The other brass item included is the ring for the top of the shaft. Comparing the supplied ring to both the picture on the card package and the actual anchor in the Australian museum, it looked too small so I made a new larger one from 0.5mm brass wire as shown in Photo 2. This is being gripped in a pair of sprung tweezers ready to start ‘Puddening’ the ring. To prevent the iron ring from cutting into the anchor cables, the ring was bound around with rope which could be replaced whenever it began to wear through. I used a white Humbrol Rigging Rope of 0.3mm diameter which can be seen tied around the tweezers. After applying a drop of super glue to the knot I then began to wind the rope around the ring, applying tiny drops of super every three or four coils to keep it tight. The completed ring is shown attached to the shaft in Photo 3, after the wooden stock was dyed with Admiralty Ebony wood stain and the blackened inner brass squares had been glued in place. The completed anchor with it’s cable is shown glued into place with two part epoxy (Poundshop cheapie) on the seabed in Photo 4. Note also that the sandy bottom is now a sandy bottom with the real beach sand pva’d into place.
Now for those barrels. The crew dumped a great number of barrels over the side along with the iron hoops from emptied barrels in the hold. Most of the whole barrels contained stores which had already gone bad which saved the crew from some nasty ‘ready meals’ later on! I found a couple of old Constructo wooden barrels left over from my very first wooden ship the ‘Grimsby’ (they were actually extra ones I bought from the model shop and never used). These are shown in Photo 5 having a short length of wooden dowel glued on the top, the reason for that is shown in Photo 6 – tiny little silicone moulds so I can cast as many as I want in resin. Not only that, but by using the Roto cast resin instead of the solid form I can make hollow barrels in the same moulds!
Tomorrow we meet Mr Mandible and the finished barrels along with some lumps of old iron!Blink
Until then…
Guest (10)
3 Pages <123>
This page was generated in 0.684 seconds.
