13 Pages «<56789>»
Anakin Skywalker's Podracer Diorama Options
#121 Posted : 14 June 2018 12:04:32
BigGrin Very nice work as always MarkCool
#122 Posted : 14 June 2018 20:05:57
Love the replacement seat
#123 Posted : 14 June 2018 22:15:44
Thank you Andy,Jase for you comments.
#124 Posted : 16 June 2018 22:44:13
Coming along beautifully Mark, amazing work....Drool Drool
#125 Posted : 17 June 2018 21:03:08
Many thanks for your comments Alan.
I have finished filling all the seam lines and sanded down several times to get a smooth finish over several days. I then masked off the internal area and resprayed with silver aluminium. The inside of the side engine flaps were highlighted and painted, although you won’t see these unless you look inside. The bottom cooling pads were also attached and then highlighted with some wash. Finally, I attached the two side panels/flaps.
I just have the top wing vents to fix into place once I have painted them. Then it is onto applying the blue markings on the panels and then a varnish finish.
Thank you for looking.
#126 Posted : 17 June 2018 23:18:34
Great to see another fab update, looks superb....Drool Drool
#127 Posted : 18 June 2018 07:33:24
A lot of work going into this Cool
#128 Posted : 18 June 2018 07:39:17
BigGrin Coming together nicelyCool
#129 Posted : 18 June 2018 07:58:15
Thank you for the kind comments and support, very much appreciated.Cool
#130 Posted : 18 June 2018 15:16:24
Cool Hi Mark looks stunning. BigGrin Drool
godan61
#131 Posted : 24 June 2018 20:33:44
So looking forward to seeing this come together and all lit up its a stunning piece of work.
#132 Posted : 14 July 2018 10:03:05
The pod has had a coat of gloss varnish before applying the decals. As you can see in the first few pictures, the placement for the decals in the instructions differ from the original prop version. The front part of the pod on the original prop has the blue markings up to where the windscreen goes, whilst the model instructions have the decals beyond the windscreen which is wrong.
I did have a bit of an issue, as it was not as simple as moving the decals down as I originally thought. I had some cutting and rearranging to do to get them in a similar place to where they are on the original prop version. I didn’t place all the decals on at the same time as there were so many to put on, and the pod is a little over 7cm long and I didn’t want to dislodge any whilst handling the model. The whole process has taken me over a week, but I’m quite pleased with the results.
Once I had them all in place, I used some polished aluminium to chip the blue marking, giving them the worn look. I then gave the whole thing another coat of gloss varnish. This is now ready for the final weathering stages once the rest of the parts are in place.
You will also see I have painted the seat and head cushion and fixed them in place. Before doing so I bound the main seat with some hessian strips as is shown on the prop version.
Thank you for looking, more soon.
#133 Posted : 14 July 2018 17:07:55
#134 Posted : 14 July 2018 22:31:07
Great progress on this MarkBigGrin Looking good with the decals on.
#135 Posted : 14 July 2018 23:59:02
Looking special Mark, fab work....Cool Cool
#136 Posted : 15 July 2018 00:35:11
Amazing work Mark. WTG
Cool Cool Cool Cool
#137 Posted : 15 July 2018 09:34:43
Many thanks for looking in guys and your comments.Cool
#138 Posted : 15 July 2018 15:54:32
Nice work MarkBigGrin missed loads of your updatesBlushing great to be able to contribute againBigGrin is an outstanding build Drool regards PhilCool
godan61
#139 Posted : 22 July 2018 20:35:07
Loving the detail and weathering
#140 Posted : 24 July 2018 14:44:24
Really coming to life now mark. well done. Cool BigGrin
Guest (8)
13 Pages «<56789>»
This page was generated in 0.806 seconds.
