screws Options
astracrazy
#1 Posted : 28 June 2011 11:55:06
Hi
I was hoping someone can help. I've mucked up on my front suspension (rounded the screws) and need to find replacement screws. Its issue 10-11 i think. What size screws are they and where can i get them from? I've seen tips for using lubricant when screwing them in so i'm gonna try that.
Thanks
astracrazy
#2 Posted : 28 June 2011 20:52:14
fixed - my screw driver was slightly too big. at least from now on it will be better!
scottww86
#3 Posted : 29 June 2011 11:03:50
I had the same prolem! There is a spare screw with each "set" of screws we get. Mine was down to a broken screwdriver!
Skiddy
#4 Posted : 29 June 2011 15:34:07
Go buy a set of these on ebay 120686481203. 6 fantastic screwdrivers and worth every penny.
Not worth buying one at a time
dvb247
#5 Posted : 14 August 2011 10:54:41
Rank: Beginner Level 3
this is the problem I'm having, but I have the Wera PH 00 driver, di I need the set of 6?
It would make sense if this was the problem as the suspension screws (only) just don't seem the right fit to my Wera screwdriver?
This page was generated in 0.174 seconds.
