It's time to join the Rebel Alliance...Are you ready for the ultimate Star Wars X-wing model?
https://youtu.be/JlUSRCnYOsE
Available in the USA here: https://www.model-space....-wars-x-wing-model.html
X-wing Model Specifications
Scale: 1:18 X-wing era - A New Hope (Battle of Yavin) The X-Wing model replicates the X-wing that was assigned to Luke Skywalker to fly as a member of Red Squadron under the call sign 'Red Five' 29.3 inches long, 7.4 inches high, 25.7 inch wingspan Weight: Approx. 8.8lbs
Official Disney Lucasfilm licensed product.
X-Wing Model Features
Laser Cannons: Each of the highly detailed cannons includes a model of the internal laser generator, plus an LED and fibre optic that lights up to mimic ‘firing’.
Removable Hyperdrive Section: The top section of the rear fuselage behind the droid socket lifts off to reveal a fully detailed hyperdrive unit, which is removable for inspection.
Proton Torpedo Bay: The lower panel in the fuselage is detachable, allowing the rack containing the proton torpedoes to be removed or reloaded.
Authentic Finish & Markings: Your X-wing comes pre-painted with markings based on Industrial Light & Magic’s models that were used to film the special effects shots in the first Star Wars movie.
Fusial-Thrust Engines: The outlet nozzles on the X-wing’s four S-foils light up to simulate the powerful thrust from its four sublight engines.
Sublight Engines: Each of the four engine cases have fully detailed internal workings that you assemble and install as you put the model together.
Movable S-Foils: The four S-foils are motorized, and open via remote control.
Cockpit: The canopy opens to reveal a superbly detailed interior with illuminated instrumentation, including the targeting computer.
Light-up R2-D2 unit: Your X-wing model comes complete with a scale replica of R2-D2. When inserted into the X-wing’s droid socket, R2’s head can turn and his sensors light up via remote control.
Landing Gear & Mounting Point: Your X-wing features landing gear that can be fitted to display your model on a shelf or table. You can also remove the landing gear and attach a mounting bracket to display the X-wing in flight mode. (A wall mount bracket will be made available to purchase via the ModelSpace online shop).
Made of Metal and ABS plastic., Each issue contains fascinating Star Wars facts and insights, along with an assembly guide with clear, step-by-step instructions, accompanied by detailed photos, to make building your X-wing as easy as possible.
This is a must-have model for any Star Wars collector or X-wing fan!
Joined: 21/01/2016 Posts: 38 Points: 114 Location: Queanbeyan, NSW, AU
I'm so waiting for this to hit Australian shores. I know it's going to be a while and Australia will need a new distributor after Bissett ceased business but by the time it does hit I'll be ready
Joined: 19/05/2015 Posts: 1,419 Points: 4,272 Location: Darmstadt, Germany
Any sound effects for engines, lasers, foils or R2?
greyhawk wrote:Any sound effects for engines, lasers, foils or R2? It’s just lighting effects - laser cannons, instrument panels and engines.
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,412 Points: 22,546 Location: Northamptonshire, England
Looking forward to this, should be a great build.
There are a lot of happy Star Wars fans drooling right now Al
 Cant wait for this one Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Tomick wrote:greyhawk wrote:Any sound effects for engines, lasers, foils or R2? It’s just lighting effects - laser cannons, instrument panels and engines.
Found a soundboard here Greyhawk:- http://www.realmofdarkness.net/sb/sw-xwing/Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Star Wars: 15 Things You Never Knew About X-Wings X-Wing FactsRegards Markwarren (Mark) Admin
 I can see a lot of custom options with this build. Regards Markwarren (Mark) Admin
 Now that looks good Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
It is really does look a good size kit. I have a 1:18 scale Luke to go inside which I’ve had for a while. Regards Markwarren (Mark) Admin
Release it already!! the anticipation is killing me !!!!!!!!
“PATIENCE YOU MUST HAVE my young padawan” Regards Markwarren (Mark) Admin
Coming this August in the USA: Build your own X-wing!
https://www.model-space....-wing-model-coming-soon
Pre-order will be live soon! Tomick attached the following image(s):
Markwarren wrote:“PATIENCE YOU MUST HAVE my young padawan” HAHAHAHA August is almost here. Carl
darbyvet wrote:Markwarren wrote:“PATIENCE YOU MUST HAVE my young padawan” HAHAHAHA August is almost here. Carl 31 days can seem a very long time
Just an FYI.MY finger is poised above the order button.And its getting a bit tired. darbyvet attached the following image(s):
