13 Pages «<678910>»
Anakin Skywalker's Podracer Diorama Options
#141 Posted : 24 July 2018 16:43:43
Thank you guys for your kind words.Blushing
#142 Posted : 01 August 2018 18:07:02
A little more done to the pod. The first picture shows the pod racer in the movie and how the weathering looks with scorching from the engines. This is how I wanted it to look on the diorama. I have also worked out a way to hide the rods that will hold the pod and engines in place with the wiring inside. There is still much more detail to add along with the screen, satellite dish and Anakin himself.
More soon
#143 Posted : 01 August 2018 19:19:40
Looks absolutely fantastic MarkDrool regards PhilCool
#144 Posted : 01 August 2018 22:56:29
Stunning Mark, simply stunning....Love Love
#145 Posted : 02 August 2018 02:54:56
Superb work Mark BigGrin
#146 Posted : 02 August 2018 06:15:20
Looks great you want tnget in and take it for a spin
#147 Posted : 02 August 2018 06:45:36
#148 Posted : 02 August 2018 08:49:17
Thank you all for your kind comments.BigGrin
godan61
#149 Posted : 12 August 2018 19:32:01
Looks just like the real think stunning work
#150 Posted : 12 August 2018 22:09:43
Looking stunning Mark, well done.Cool BigGrin
#151 Posted : 12 August 2018 23:57:44
Stunning work.Your weathering is absolutely perfect.its so hard to do really authentic looking weathering and you have totally nailed it.Cant wait to see the finished model.
#152 Posted : 13 August 2018 22:38:56
Many thanks for your kind comments guys.
#153 Posted : 29 August 2018 22:36:20
The pod is almost complete. I have finished weathering with some sand colour and exhaust soot and then varnished it all with some vallejo satin varnish.
The next step was to fit the windscreen in place. This was made from a piece of clear acetate, with some heat shrink tubing cut and place at the bottom of the screen to represent the rubber. This was not an easy task, I had to roll the acetate to give it a bend before I glued into place. I then weathered the glass panel slightly with sand oils to match with the rest of the model.
I still have the antennas to apply, but this will be done at the final stages of the diorama, so not to damage them.
I just need to finish off the engines and then onto the diorama itself.
More soon, happy modelling.
#154 Posted : 30 August 2018 07:22:40
CaptnBirdseye
#155 Posted : 30 August 2018 19:44:15
Rank: Superelite
Your pod weathering looks really cool Mark ThumpUp ThumpUp
#156 Posted : 03 September 2018 15:14:35
Looks stunning Mark. very well done. Cool BigGrin Drool
#157 Posted : 03 September 2018 19:49:04
Great weathering Mark, superbly done.
#158 Posted : 04 September 2018 07:36:34
Thank you guys for your comments and support.Blushing
#159 Posted : 26 September 2018 10:08:13
Just a very quick update on the diorama. I’m finishing off the actual model parts before I start to construct the diorama itself. Here, you can see the link cable between the pod and the engines. You will note the hook on one end, this is placed/attached on the end of the cable attachment fixed to the pod as shown. This not only looked ugly but was very wrong to the original, so, with a little work I have adjusted the cable accordingly to fit where is belongs. I have also had to reshape the cable parts to fit around the pods front section allowing to rest on the cable support.
More soon.
RM1
#160 Posted : 26 September 2018 16:10:15
That looks very cool.
Malc.
13 Pages «<678910>»
This page was generated in 1.325 seconds.
