Stern curvature help needed Options
Deepseacodmaster
#1 Posted : 29 June 2011 10:29:08
Hi All
Can anybody post two templates of the stern curvature I need to sand down to.
I am having trouble getting the correct shape.
The templates could be taken over installed planking.
I have drawn the approx. positions of the templates I need in the photo.
Your help would be greatly appreciated because I am a novice in all this.
First Build HMS Victory and HMS Endeavour
Also Krick steam boat "Victoria"
Cheers
Ivan (Ordinary Seaman)
http://www.old-glossop.com
#2 Posted : 29 June 2011 10:40:43
Is this what you are after Deepseacodmaster...BigGrin
The stern will need to be taken back to the false keel on the rear-most frames...BigGrin
#3 Posted : 29 June 2011 10:41:11
Firstly you need to sand the frames so they are flush with the stern post, and then start to shape the frames as per this photo
#4 Posted : 29 June 2011 10:42:42
Deepseacodmaster
#5 Posted : 29 June 2011 11:13:58
Thanks Mr T
That is the area,
Appologies for using your photo.
This is the area I may need a template for.
However your photo has given me a good idea of what to achieve.
Cheers
Deepseacodmaster
#6 Posted : 30 June 2011 08:58:23
BigGrin
7 hrs later I have managed the starb stern curvature correctly.Mellow
The above quote is very important espescially to beginers like me.
Thanks to Jonny and Mr T for the photos BigGrin
Cheers
This page was generated in 0.357 seconds.
