Thanks chaps for your kind comments. Rich
Great looking interior Malc.
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,291 Points: 22,180 Location: Northamptonshire, England
Very nice work Rick, looks excellent. Mark Regards Markwarren (Mark) Admin
You're right Richie, it's those little touches that transform the build Liking the mods. Regards Gray
Thanks Chaps, good to know your looking in on the build. All the best Rich
Dashboard complete, just a couple of tiny mods - yellow stripe added to steering wheel, and radio blanked off. Thanks Rich. TRGRichie attached the following image(s):
Lovely work Rich. Mark Regards Markwarren (Mark) Admin
It’s the details that make all the difference, keep the pic’s coming
Joined: 09/02/2018 Posts: 30 Points: 90 Location: Oststeinbek
TRGRichie wrote:Stage 6
Just incase anyone is still following the build heres the stage 6 update.
Sprayed the interior tub white and then carpeted (including rubber matts)
drivers seat built and fitted.
engine fitted to chassis and the exhaust fitted and sprayed. Hi Richie, Great work, how did you create the carpet matts? Andrees My builds: Shelby 99%, Porsche Carrera RS 30%
 Looking good Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Andreesb wrote:TRGRichie wrote:Stage 6
engine fitted to chassis and the exhaust fitted and sprayed. Hi Richie, Great work, how did you create the carpet matts? Andrees The rubber ones or the general Carpet? Thanks Rich.
Stage 8 just a couple of pic for Stage 8, added extra detail and colour and hose clips to the heater unit. I'm waiting a replacement Body as it unfortunately turned up with some damage - will post pics of this part of stage 8 when it arrives. Thanks Rich. TRGRichie attached the following image(s):
Envious build Ritchie  You're certainly putting the effort in there. Will certainly look fab when you've done Regards Gray
Excellent build, lovely work Mark Regards Markwarren (Mark) Admin
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,751 Points: 17,405 Location: ipswich
Looking really great so far.
Sadly though, the inner orange hoses, clips and cross-rod will be completely lost in the next stage unless you leave out the cover - which you could...
roymattblack wrote:Looking really great so far.
Sadly though, the inner orange hoses, clips and cross-rod will be completely lost in the next stage unless you leave out the cover - which you could... Hi Roy, yes I intend to leave the cover off, from looking at a lot of the reference pics i've found this seemed to be the case with the real cars too. Thanks Rich.
Looks good with the coloured pipes and clips  nicely done. Al
TRGRichie wrote:Andreesb wrote:TRGRichie wrote:Stage 6
engine fitted to chassis and the exhaust fitted and sprayed. Hi Richie, Great work, how did you create the carpet matts? Andrees The rubber ones or the general Carpet? Thanks Rich. The rubber ones! My builds: Shelby 99%, Porsche Carrera RS 30%
Andreesb wrote:TRGRichie wrote:Andreesb wrote:TRGRichie wrote:Stage 6
engine fitted to chassis and the exhaust fitted and sprayed. Hi Richie, Great work, how did you create the carpet matts? Andrees The rubber ones or the general Carpet? Thanks Rich. The rubber ones! Hi, I used a bicycle inner tube for the rubber mats, make sure you use a light weight one for a mountain bike, these are a good thickness and wide enough once cut. Thanks Rich.
Great work on this model Rich! Looking great! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Guest (11)
