5 Pages «<2345>
Al's Robi Options
#61 Posted : 08 June 2018 23:15:28
The little fella is growing to be a big fella, looking good Al....Cool Cool
#62 Posted : 09 June 2018 08:14:00
BigGrin Looking good Al and glad to be of helpCool
#63 Posted : 09 June 2018 08:58:33
Taking shape very nicely Al. Cool
#64 Posted : 09 June 2018 11:26:03
Thanks guys BigGrin
#65 Posted : 06 July 2018 22:38:03
Pack 14
In this pack we get to finish Robi's left leg by fitting his hip servo and hip frame then testing the leg function.As the test was fine His legs were then joined using the hip base, front and rear panels and a further test function was carried out, again with success.
Now Robi's head is removed from the neck stand so his scarf can be removed and the new neck base fitted.Finally another servo was assigned its id ready for the next part of the build.
#66 Posted : 07 July 2018 07:14:09
BigGrin Looking very nice and just a few packs to goCool
#67 Posted : 07 July 2018 09:08:05
Another very nice update Al, won't be too long before he's all done....Cool Cool
#68 Posted : 07 July 2018 09:41:18
Nice one Al, not too long before the little fella is dancing around.
#69 Posted : 08 July 2018 00:06:26
Thanks for the comments guysBigGrin looking forward to getting the last few packs.
#70 Posted : 04 August 2018 23:10:18
Pack 15
A fair bit to do in this pack and some major components to join. Firstly the speaker was mounted and then attached to Robi's left arm and body assembly.The on off switch was fitted to the scarf and neck servo fitted, at first I put the servo in incorrectly, see pic, but on checking with the instructions I realised my error and sorted it before the next stage. Now we get to another milestone and carefully start connecting wires to the circuit board before closing up the two body halves. Finally for this pack we test and fit yet another servo into the body, only 3 packs to go nowBigGrin
#71 Posted : 05 August 2018 08:04:10
BigGrin Looking good and not long to go now.
Double check the servo wire that runs from the left arm and through the speaker assembly has plenty of slack as it may cause problems laterCool
#72 Posted : 05 August 2018 08:33:27
Looking good Al, lovely progress.... Cool Cool
#73 Posted : 06 August 2018 00:07:25
Thanks for looking in gents BigGrin thanks for the tip Andy.
#74 Posted : 06 August 2018 00:13:16
The little fellow`s looking good.
Cool Cool Cool Cool
Awaiting the next update.Drool
#75 Posted : 06 August 2018 00:28:57
Thanks Derek, only a month to waitBigGrin
#76 Posted : 10 September 2018 11:27:30
Pack 16
More progress on this little fella, once the neck plate was secured Robi's arm neck and back functions are tested along with the speaker. Have to admit I let the test run for several cycles just to hear him say okayBigGrin Next the head servo frame and lever were attached to the neck servo and the foot pads stuck onto his feet.The two head servos were fitted and another function test was carried out with no issues.Then the servo horns and head base were attached and we dismantle Robi's head in order to fit an infrared unit into one of his eyes.Finally the head frames were fitted to complete this pack.
#77 Posted : 10 September 2018 11:44:32
Looking good Al, you can see the finishing line.
#78 Posted : 10 September 2018 18:20:22
BigGrin coming together nicelyCool
#79 Posted : 10 September 2018 22:29:03
Great to see another update Al, all looking good....Cool Cool
#80 Posted : 11 September 2018 02:21:40
Thanks all for looking in BigGrin
5 Pages «<2345>
This page was generated in 0.205 seconds.
