Kit Equipment Options
Russ
#1 Posted : 14 August 2018 15:43:10
Rank: Beginner Level 1
Hi There
just bought the full kit and this is my 1st build in years and I have no tools to make this, can anybody please recommend what I will need?
RussDrool
#2 Posted : 14 August 2018 16:10:55
If it's just for the Cross-section build:
Modelling Knife & spare blades
Razor saw & mitre box
Micro Drill & assorted micro drill bits
Map Pins
PVA wood glue
Superglue
Cutting Mat
Asstd Needle Files
Sanding block
Various grades of sandpaper - course to very fine.
Mini Clamps
Tweezers
Steel Rule
Mini set square
Build board for the cross-section frame assembly
This set provides a number of the basic tools
https://www.model-space....modelling-tool-set.html
Also this is a useful set
https://www.model-space....gb/micro-ruler-set.html
All of the tools can be found on eBay or via CMB (click on the Tools tab)
https://www.cornwallmodelboats.co.uk/
Russ
#3 Posted : 14 August 2018 16:30:35
thats great thank you.BigGrin
This page was generated in 0.101 seconds.
