Vasa Stage 24 & 47 update. Options
#1 Posted : 15 August 2018 12:05:00
The two decorations C30 and C31, received in Stage 24 have been revised and therefore do not need be painted but be discarded.
Revised parts C30 and C31 are supplied with Stage 47. You should paint the revised parts as per the painting guide within Stage 24, they will be fitted to the stern area in Stage 118.
Per Ca
#2 Posted : 27 August 2018 12:27:28
Rank: Amateur Level 1
Do you know what happens if the build is well passed stage 47? Will the replacements be included in the next delivery (which for me will be stage 119-122)?
#3 Posted : 27 August 2018 13:55:02
We’re unable to comment regarding your provide content as the UK has no dealings with this and therefore you need to ask the question of them.
Per Ca
#4 Posted : 28 August 2018 11:19:42
I beg you to excuse me, I didn't understand that this was an exclusive UK site only. However I am surprised that the deliveries in UK hasn't advanced more than to stage 47, so that all UK builders have this replacement.
#5 Posted : 28 August 2018 13:13:03
You misunderstand, the ModelSpace Vasa kit is not supplied by Atlas; all ModelSpace Vasa stock is supplied direct from the manufacturer and contains latest parts updates and also update of the instructions. ModelSpace stock is in fact at issue/stage 77.
Per Ca
#6 Posted : 13 January 2019 18:32:32
I guess many builders were passed stage 47 when this message came, so what happened there? I have now recieved the final package with stage 137-140, and there they were. Two griffons, a tiny bit smaller than the original ones. BUT also a new part C28, the "half-moon" shaped frame, and this had a slightly thinner lower beam, giving more room for griffons, king and crown. But no explanation whatsoever. So those who are waiting for those parts, don't despair!
Peo Engberg
#7 Posted : 01 April 2019 10:53:33
Rank: Newbie
Today I checked ,and there they are.....
This page was generated in 0.161 seconds.
