80 Pages <12345>»
DaDokta
#41 Posted : 17 August 2018 06:42:22
Absolutely stunning!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
Sticky Wickett
#42 Posted : 17 August 2018 12:29:13
Beautiful update and very well engineered. Looking fab....Drool Drool
Hi Alan, thank you very much for looking in and your comments.
Phil W
Sticky Wickett
#43 Posted : 17 August 2018 12:30:01
Markwarren wrote:
Very nice work Phil.Love
Thank you for looking Mark. Glad you like the mods!
Phil W.
Sticky Wickett
#44 Posted : 17 August 2018 12:31:02
Thank you Walter for looking in and your comments.
Phil W.
daffy09
#45 Posted : 17 August 2018 12:42:57
Cracking work Phil, I'm loving the 'mod' on the conning tower. She's going to be a pretty unique build when she's finished.
Happy building
David
Sticky Wickett
#46 Posted : 17 August 2018 12:59:51
Happy building
David
Thank you very much David! Now the weather has cooled a bit I can crack on.
Phil W.
#47 Posted : 17 August 2018 19:22:29
Very impressive work. WTG
Cool Cool Cool Cool Cool
#48 Posted : 17 August 2018 20:36:51
Great to see this coming along Phil BigGrin very nicely done.
#49 Posted : 18 August 2018 08:00:57
BigGrin Looking very good with the modsCool
Sticky Wickett
#50 Posted : 20 August 2018 13:06:14
Thank you very much Del!Cool
Phil W.
Sticky Wickett
#51 Posted : 20 August 2018 13:07:33
Thank you very much Al!Cool Hoping to get back into more of a routine now it's a bit cooler.
Phil W.
Sticky Wickett
#52 Posted : 20 August 2018 13:08:25
Thank you very much Andy!Cool
Phil W.
#53 Posted : 20 August 2018 19:04:04
Glad to see your progress PhilBigGrin the scratch building is superb Drool regards PhilCool
Sticky Wickett
#54 Posted : 21 August 2018 11:24:00
Thank you very much Phil!Cool Now it 's a tad cooler I can get back into the swing of it.
Phil W.
#55 Posted : 21 August 2018 11:29:42
The mods are coming along well, she is going to look superb.
Sticky Wickett
#56 Posted : 21 August 2018 12:11:41
Thank you Graeme!Cool Plenty more to do but progress nonetheless.
Phil W.
Sticky Wickett
#57 Posted : 23 August 2018 21:24:14
This weeks update of my 1/48 scale model of U230 sees the continuation of adding made to measure, 0.5mm thick plastic panels to connect the base and the lower deck of the conning tower.
What a tricky old job it's been!Blink. I've succeeded in fitting 8 panels this week, taking me approximately 10 hours!Blink
It wasn't just a case of cutting out a square shape to fit as the two sections to be joined have different diameters. This meant I had to bend the top and bottom of each panel to suit and then twist the whole section to accommodate the taper.
The attached photo shows what I mean. I also marked an arrow indicating the top so as I didn't fit it incorrectly.
Sticky Wickett
#58 Posted : 23 August 2018 21:25:13
This photo shows the same panel being test fitted.
Sticky Wickett
#59 Posted : 23 August 2018 21:27:14
The same panel, this time holding itself in place, while I check it for fit.
Sticky Wickett
#60 Posted : 23 August 2018 21:27:59
This time it's glued in place.
Guest (6)
80 Pages <12345>»
This page was generated in 0.287 seconds.
