 Looking good and nice work Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 16/04/2011 Posts: 328 Points: 998 Location: Anglesey
Hi, Decided to do something Regards the opening compartment doors. I did not like the way they where proud of the body, so I have done my best to make them flush. Just a bit of sanding and tweeting and I think will look alot better when all painted. Spudtrooper37 attached the following image(s): Darren
Have an AWSOME day and may the Force be with you always 😉 Building: Millennium Falcon https://forum.model-spac...sts&t=14381&p=7 - Building: BTTF Delorean - Building: Dom's Dodge Charger - Building : X-Wing https://forum.model-spac...aspx?g=posts&t=34899
Coming along nicely
Nice work Darren. Mark Regards Markwarren (Mark) Admin
 Looks good to me Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Looking good Darren, nice work.
Thanks everyone, finally got some parts that I can start work on (painting and modifying) Issue 84 Did not like the hollow on the back of the arms, so a piece of 1mm styrene sheet corrected this and also this made the arms sit flush with the body Alot more happy with the way this looks The bottom pic shows the modified bottom arm sitting flush. Spudtrooper37 attached the following image(s): Darren
Nice work Darren, looking very good. Mark Regards Markwarren (Mark) Admin
A little update on R2's modified arms These have now been painted and weathered Now look more solid. Also a bit of weathering and paint on the compartments (still need to do something else on them but don't know what) Spudtrooper37 attached the following image(s): Darren
Lovely work Darren. Mark Regards Markwarren (Mark) Admin
That`s looking very good. Like the weathering. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Test video of the arms in action https://youtu.be/afqGmr9LZTgDarren
Hi. Thank you for stopping by and leaving nice comments. Hope everyone is enjoying there R2D2 builds. I'm getting really excited now. 14 more issue's to go 😁 Finally started on the painting and weathering of the front panel. All three sections were glued and filled to hide the joints. Primed and painted white. I have done two of the compartment doors, these were painted aluminium on the inside as seen in ANH. Not built the tool arms yet, don't want to rush things. Last two pictures from ANH shows the silver on the inside of the doors and the interface arm. Spudtrooper37 attached the following image(s): Darren
My bottom arm was catching on the body as it closed, I found that the arm was loose within the pivot mount causing it to sag. So I stuck I piece of plasticard to the underside of the pivot mount and filed the recess slightly bigger than the original. Spudtrooper37 attached the following image(s): Darren
Lovely work Darren, your attention to detail is superb. Getting really excited now, nearly there. Mark Regards Markwarren (Mark) Admin
Joined: 04/05/2011 Posts: 173 Points: 528 Location: Sussex
Thats looking really good. Loving the colour of the blue you have achieved.
lholland wrote:Thats looking really good. Loving the colour of the blue you have achieved. Thank you, it is Citroën Posiden Blue. Darren
